skilltube is awesome on hc servers
why i used to use it all time great rage inducing weapon.
Oh you still play? Thought you'd given up ages ago with all your comments about how rubbish it is. If you're not careful people might think you find the experience enjoyable.
I'm just trying to picture the amount of abuse you would have got from American kids, that chat window must have been going mental.
They were going mentalI was in stitches. caught two squads spawning in the locker in one go..
Probably pretty potty mouthed too, as is the style.
M320 is your top weapon overall and you have 17 service stars with support, which explains the 10% accuracy.
I am disappoint.
 I was in stitches. Caught two squads spawning in the locker room in one go..
I am disappoint.
	^^ You haven't somehow left V-Sync / forced it through drivers / Limited your FPS have you? Oh and what maps? Specifically Karkand maps are terribly optimised.
	Hmm those maps are as smooth as butter for me. I see you have a quad @ 4ghz, that should be MOAR than enough for BF3, I spose it could be your RAM...but I doubt it.
Have you installed MSI with RTSS and set up a FPS limit there? May I suggest you enable FPS in Afterburner as well so that you can tell whether there is any correlation between FPS and GPU usage.
What in game settings are you trying to run this on btw......I have a nice PC but only run at low for being able to see people better, if you are trying to run ultra on your setup I would not be surprised if it is your RAM.
drop every setting to low except mesh quality and just play with limited fps! Only way to play tbh!
Defo do this, when you are playing there is no real difference between Ultra and Low.
