Quality is wrong.
CHEAT!![]()
Glad you saw that. It made me worry about my score!!!
Quality is wrong.
CHEAT!![]()
Heaven 4.0 screenshots are in .TGA format how is everyone converting them, or how are you capturing the screen to show the result and cobblestones.![]()
how is your card scoring so high compared to the other 780's posted?![]()
Ditto!![]()
No idea maybe it's a good one. I'm on a fresh install with nothing else running if that helps.
MOOGLEYS CPU is a generation up on mine and overclocked quite heavy by the look of it, I'm a baby so mine is at stock and that is party due to my old Fermi card making my PC case an oven and it effected my CPU temps which would idle around 50c, already with my 780 they are idle around 38'ish so with a bit of help from someone here maybe I'll overclock my CPU and re-run Heaven.
In the meanwhile I overclocked my 780 just to match EVGA's pre-clocked card and the difference is just shy of 100 point increase.
Could you post what clocks you are using please.![]()
14. Score 1479, GPU 780 @1163/1582, CPU i7 950 @4.0, OCPete
15. Score 1286, GPU 780 @863/1502, CPU 3570k @4.1, mcleish
320.18 drivers, i7 950 @ 4GHz HT enabled.
Air cooled GPU, ref cooler, default fan profile
Core Boost 1175.8MHz
Memory 1612.3MHz
That's about all I can get on the core. Not hit the memory limit yet.
That's quite a big overclock already Pete, and still it's not matching MOOGEYS whose running at stock, it HAS to be his CPU making the difference.
