Np, I wasn't being funny or owt
Did not think you was I like posting pics as my explanations are usually crap.
Did not think you was I like posting pics as my explanations are usually crap.![]()
Now thats a new wrinkle in my @rse so to speak lol
This is everything at stock. It shows the same as precision.
1006 MHz at stock? what brand do you have again? all I've seen are 863 at stock or EVGA's pre-oc card at 941 and 967 on their ACX card. 941 is what I matched on my ZOTAC for my second Heaven score posted earlier.
At 1013 GPU clock my boost is 1052. I wonder if EVGA have done some other kind of tinkering with the ref cards, need to see some benchmarks from another EVGA user.
Are you getting that reading from gpu-z main page or sensors after running the benchmark? The actual boost will be higher than 1052. If it isn't then try increasing power limit and voltage. There's no difference between the evga cards and others.
Was from gpu-z main page.
Just put 150 on the memory clock too, so 1652 clock and it performed slightly worse then 1502 clock.
Sometimes I've seen results go lower for no apparent reason but simply closing and reopening the heaven application fixes it.
14. Score 1479, GPU 780 @1163/1582, CPU i7 950 @4.0, OCPete
15. Score 1286, GPU 780 @863/1502, CPU 3570k @4.1, mcleish
OCPetes clock's are the boost clocks but mcleish is non-boost. It can be a bit confusing, maybe ask people to post both base clock and boost speeds?
I think its worth noting the cooling on the GPU too.
Air / Water
Ref / WF 3x etc
Good plan?![]()
doh got 1483 with my 780 evga superclock and seems to be stable at 1137mhz and 1674mhz. Was so hoping to take out 1 titan![]()
Cheers kaap, im just a little bit dissapointed the new card isnt much of a clocker compared to my original. Regarding the case and cables, ive grown to hate my bitfenix shinobi xl with a passion. Terrible airflow, a dust magnet uptop. Im saving a few pounds to get my lian li a70f full tower powdercoated and modded for better cable management, (and maybe wc ready). System would run cooler in it as well, but first i need to buy a 3770k.Not a problem, I am just happy people use the thread.
I have noticed that too, they do work well together.![]()
