- 22 Sep 2008
- Burscough
Dug up 6 deeply embedded pavers from the lawn, filled the holes with top soil ready for seeding. Turned over some soil where a trampoline used to be ready for seeding. Spent bloody ages raking the lawn trying to get rid of the deadened moss, grass and matted grass.
I also put up a curtain pole on the hollow wall in the main bedroom. Self drive metal wall plugs didn't work that well at first. I found that if you drill a 6mm hole as a guide to screw them in by hand works the best. If you just drive them in, they tend to crumble the thread it is making and end up spinning uselessly in the hole the created.
Then hung the curtains. Its been 4 months since being in my first place and its great to finally get curtains! So dark!!!!!!
