- 13 Sep 2003
- Glocestershire
Video of it in action
http://youtu.be/oct-MsEfvco
That really doesn't look like something that would go in a Starbucks overhere.
i'm pretty boring so just have a largish black bodum one that sits in the cupboard gathering dust but there are a load of nice ones out there, the double walled ones look pretty good![]()
Flicking through my Flipboard earlier came across an article that was talking about a Clover coffee machine. Starbucks bought the company that invented them and had been using them in a few stores but appear to be rolling them out in more now.
Looks like a cross between a French press and an aeropress. Would be interesting to try one and see how wel it makes a cup. Also pretty crazy expensive at around $11k I believe.
To be honest I wouldn't ever bother with a french press any more. Why not just get an aeropress?
I honestly have no idea. Maybe I should?
I like filter coffee though. If I use the aeropress and then add hot water to increase the volume, will I get **** tasting coffee?
Depending on the beans you use, you should get a very nice tasting coffee! I wouldn't want to try and make more than 2 coffees with an Aeropress though, it may be too watered down. I use a French Press for 3+ cups.I like filter coffee though. If I use the aeropress and then add hot water to increase the volume, will I get **** tasting coffee?
How about a Chemex?
Or A Kalita carafe?
Or even the V60 Carafe?
@Siliconslave: You have mail![]()
There are several Starbucks stores in the UK that have them. Cost to the store is about $5000
When I first saw them, I really wanted one. Now it's owned by starbucks... Not so much. Wouldn't want to deal with Starbucks for spares. Add to that, they won't sell them to the general public.
Ordered my Classic today as my vouchers turned up, got it for £138 incl. delivery.
I have the motta brush in basket from cream supplies
58mm tamper from above
a blanking plate from ebay
non pressurized basket from ebay
Where can I get that Puly Caff stuff that I need for the machine? Creamsupplies do Puro Caff is that similar?
Thanks! Can't wait for my machine to turn up![]()
Using the Aeropress with the inverted method gives a filter-esque coffee which is far far superior to any french press. It's a no brainer. The only downside to the Aeropress is that's it's basically impossible to make more than one coffee at a time.
Nice one alllec will order that shortly. Just had an email and text to say DPD will be delivering my gaggia tomorrow woo
