yeap 60 days is one cycle, so if i was to start now it would take me up to september.
Narrow stance squatter? i am over shoulderwidth apart at the heels, does this really class as narrow stance or just normal?
Also any lumbar control issues i have were not a consideration for considering adding in sumo.
(if i am being honest i didnt realise there was an issue there over and above general form breakage the closer one gets to there RM, which i dont ignore and i try to work on all the time)
With my deadlift, progress has always been slower then most people on here, for example i squat better then many people here who can pull 200kg no problem, but i cant shift more then 170 (180 being optimistic) and i am wondering if it is my odd proportions that are the limiting factor, being all torso and no legs.
As for working on weakness, i thought it was much harder to work on something the closer you are to your RM? My training has been very much focused on the higher end of my strength range recently. I thought movement reporgramming and form corrections were better dealt with at lower weight ranges and higher reps??
75% of RM is hardly light weight either...
What band did you use for the squat band? Might look at grabbing one to help with my knee issue too.
