****7950 (disabled) BOOST BIOS THREAD****
I TAKE NO CREDIT FOR THIS, ALL CREDIT GOES TO kahboom from Overclock.net!
After a long research on various forums there's finally a way to get round annoying BOOST function which made your Overclocking unstable, kept constant 1.25v and the jumps underload which caused big FPS drops. This BIOS modded by kahboom from Overclock.net Forum disables the annoying BOOST function which allows you to have lower voltage's with higher clocks, there are 4 profiles with clocks 1Ghz+ and the good thing with this BIOS is it works like an update for your factory BIOS so you don't have to do anything accept from flashing. So what are the real advantages of this BIOS?
- Lower voltage in idle and load
- Lower temperatures with higher clocks
- No annoying FPS drops during gaming
- 50+ power and raised 1.30v voltage limit
- No need of running overclocking tools as you have 4 profiles with different clocks 1Ghz+ to choose from.
****kahboom official thread****
NOTE: If you card is not on the list and you would like to have an modded BIOS, you can kindly ask kahboom on overclock.net forum to make you a modded BIOS. You can also visit kahboom's thread for further explanation & info.
Overclocking Software
MSI AB Beta 14+ works with the modded bios code! ***UPDATE***
Guide on how to flash your card (windows & USB method)
Windows Method
Bootable USB Method
***Download***
Working Stable Daily Ghz Profiles
HIS7950 Boost Ghz bios.zip
HIS ICE-Q Boost HD 7950 Boost Edition, 1070core 1500memory, Voltage between 1.098v to 1.180v depending on ASIC, 50% powertune, Boost function disabled. Additional profiles added.
Only 1 profile with lowered voltage [BETA] 1070/1500, Voltage between 1.090v to 1.150v depending on ASIC
HIS 7950 IceQ low voltage.rar
MSIr7950.zip
Non Boost version Msi Twin Frozr III HD 7950 1070core 1500memory, Voltage scale between 1.090v to 1.150v depending on ASIC, 50% powertune.
UEFI MSI TF3 HD 7950 bios same as above just UEFI as well
MSI TF3 Non Boost HD 7950 UEFI.zip
MSI Boost TFIII Oc 7950.zip
MSI Twin Frozr III HD 7950 Boost Edition, 1070core 1500memory, Voltage between 1.098v to 1.180v depending on ASIC, 50% powertune, Boost function disabled. Additional profiles added.
Sapphire 7950 Ghz.zip
Sapphire HD 7950 Non Boost version 1070core 1500memory, Voltage scale between 1.090v to 1.15v depending on ASIC, 50% powertune
XFX7950.zip
XFX HD 7950, Model 795A-TDJC, 1050core 1325memory, Voltage Scale between 1.13v and 1.20v depending on ASIC, 50% powertune
Remember
Before flashing remember to have the switch at position 1!
!!!WARNING!!!
I am not responsible for any damage done to your card! You flash the card at your own risk!
Windows Method
Bootable USB Method
***Download***
MSIr7950.zip
XFX7950.zip
Remember
!!!WARNING!!!
