One more question.... I haven't got a micro SD card as of yet so can I put the rom files on the phone and still flash?
Yes.
I'd be inclined to update to MEA first, I9505XXUBMEA is needed for Omega 5, WanamLite doesn't include modems. So possible wifi/LTE issues.There is no need to install a pre-rooted rom, just flash CF-root and recovery, and then flash wanam/omega and whatever else you want extra, like JB Domination/CM APK's
Cheers bud.
Mine's
Is this the latest?
What is everyone running?
Cheers bud.
Mine's
Is this the latest?
What is everyone running?[/QUOTE]
Same as you for the camera:
[INDENT][INDENT][IMG]http://img547.imageshack.us/img547/5826/sgs410.jpg[/INDENT][/INDENT]
I believe that there is an update coming when you get onto XXUBMEA which is due shortly.
Correct.So install a pre-rooted Rom first (MEA.....this will root and have the added benefit of installing the modems). Then flash Wanam?
Correct.
Thank you kind sir.
They're out on June 26. I think it will just be a process of flashing a ROM just like you would with any other, so yeah you'll be able to flash it even with a standard S4![]()
Soon as you're rooted and the custom recovery is in and it's all working (wifi etc) grab a backup of the EFS folder and a Nandroid before you move on to the roms.
There may have been a minor change or two from stock, csc area codes nothing really or it wouldn't work.How do you do this mate?
And does it matter that I've flashed a custom rom already?
So yeah always grab a copy of the EFS folder and keep it off the phone. Then even if you have a corrupted flash you can push the folder back with ADB to restore the IMEI etc. Just zip it up in something like Root Explorer.
when you say backup efs folder, do you mean literally make a copy of the folder, for example to my PC or external sd?
