ok so got the server back up and running
hopefully will be stable for the weekend unless
server decided to reinstall itself![]()
UPDATE
So a quick update
FT has done a huge amount of work on the server getting it sorted out and
updating it. I am now re-uploading all the server files for both minecraft servers.
this will take a while to complete as the world files are rather large.
Should if all goes well be back up later today
How's the mod server compared to the old one? Was only just getting to grips with tekkit then the server was changed. Bit worried it will be overwhelming.
Also Mod server seems to be down again at the minute.. Odd that it seems to only go down overnight??![]()
