Big Bike Thread
Status
Not open for further replies.
Discovered today that the right crank arm has been hitting the chainstay, no damage luckily, but it has almost gone through the framewrap.
Cannot work out why this is occurring as the crank is fitted correctly; the Atlas crank has always been a pain to install!
Apart from the dodgy as hell decision on the handlebars (9 sweep 5 bend is great, but those are by far not wide enough.... please change to good DH handlebars, please ) that looks like a wicked build. ( I'm assuming you mean mavic 823)
Hahaha, sorry! no deal! I ran those on all my old bikes, I just feel comfortable with them.
Whats the deal with the super wide flat bar thing that dh has adopted in my absence:eek::p
Yeah they are 823's:o
Are hope m4's still the benchmark for brakes these days or is there a better option
Also tires whats good these days, which ones to avoid?
Hahaha sorry! no change, I ran those on all my old bikes, I just feel comfortable with them.
Flat bars are only the rage on bikes with a high front end ( Iron Horse Sunday they make sense on). Bikes are nice and low these days, so that you can play around with rise bars to get the height just right.
Those bars of your are silly narrow - you might feel comfortable on them... until you try something better and think "WTF have I been thinking all these years" ;)
M4's I personally think are rubbish, but plenty will disagree with me.
Those bars of your are silly narrow - you might feel comfortable on them... until you try something better ;)
Fair one! might see if I can have a play with a few bars next time I pop in to my local shop.
Went to check the bike today so I can start riding to work again and the rear caliper is sticking :(
Caliper service and bleed kit ordered. Going to try do it myself rather than pay a LBS to do it and, no doubt...wait ages.
If you like Hope go for the Tech V4 on that build instead.
I'm a big fan of m4's but plenty of people recommend Shimano these days as you can pick them up cheaply from the German online shops. However the feel isn't at all like Hopes, very on / off and spares are non existent. They're certainly powerful though.
Bike after today, it was a bit wet out;
Also managed to put a surface chip in the drive side of my XO cranks, not very happy about this.
Help! Newbie bike building questions!
Just putting together a shopping list for my new frame which is a Transition Bandit but I'm confused by the front derailleur standards. According to Transition I need a High Direct Mount.
Is this here the correct fitment?
Transition also mention a 51mm chainline, the spec details on the link above mention a 48.8mm chainline. What's all that mean?
Cow I've got helitape on the faces and the boots on! This is just on the underside of the arm in the middle, will take a picture later before i tape them all up again and hope. Annoyance is I cannot remember striking anything.
Have exactly the issue on my Atlas FR cranks and SS2 frame... :(
Status
