owncloud gets mentioned a lot.
tried installing it on whs11 and couldnt get it to work.
Thanks, I'll give it a go.
I've given up on WHS11. Tried installing it virtually but it keeps crapping out. Going with Server 2008 R2.
Guys,
Currently have a NL40 with 8Gb of Ram and 3 Hard drives (non raid) running Windows 2008 R2 64bit as a home server.
However may have the chance to upgrade free to a NL54. Just wondered if its just a case of swapping everything out from the 40 to the 54, boot her up and done? Or are there any fundamental chipset changes which would not allow me to do this?
Mark
For people using Lights-Out.
Once the trial period has ended, is there a need to buy the license or will the free (community) edition be functional enough?
I haven't installed it yet, but basically I'll want to:
Have server (WHS2011) off most of the time, but wake up on access from another device for media streaming (LAN & maybe WAN), plus wake itself up to run the client backups.
Will the freebie version still do that?
Ta![]()
Just to be clear guys, I'm not talking about integrated lights out by way of the add in card, but the software that is Lights-Out
There are plenty of mentions of it further back in this thread so I know it is being used but I can't find a specific answer to my question. I don't mind buying a license if I need to as it's cheap enough but I'm not one for buying stuff I can get for free![]()
lights out reports i have no suspend option available on my n40L?
Got my N54L yesterday and now(with lots of help from a mate) put synology on.
I'm getting from Nas to PC 90-100MB sec Pc-Nas 75-80MB sec. So I'm very happy
As it's a port I'm not trusting it fully yet. All the synology Android apps work and streaming video is awesome.
Now to buy some more HDs
Synology is very good (I've been uding it for a few weeks) but only drawback is that it does not spin down the hard drives when not in use
I haven't got that far yet still moving data. My version is microserver-dsm-4.2-02.05.2013 I have also moved over the new modules.
Can you tell me is it ok to leave out the USB stick when I shut it down or does need to boot off that all the time?
It boots from the USB stick, you can leave it out when shutting down just not booting back up again.
