Man of Honour
Use a proxy plunger.
I honestly never had this problem before one of those "eco-flush" toilets was fitted. Not really much economy if you have to flush the toilet fifty extra times. In any case I'll give the hot bucket of water a go.
I generally just leave it for the next person to deal with. At the end of the day, I've already used it and won't need to again for a while. So the next person either deals with it or ***** themselves.
You can try using a mop with a round head. Works quite well. Like a plunger
You haven't been flushing down baby wipes have you? So many retards do this and don't know the damage they cause.
Would never recommend any form of plunger, almost inevitable that you are going to get a face full of something. Except a set of drain rods, because then you can stand well back
yea the toilet where I moved to has a crap flush and I'm on what should be the 4th floor.I honestly never had this problem before one of those "eco-flush" toilets was fitted. Not really much economy if you have to flush the toilet fifty extra times. In any case I'll give the hot bucket of water a go.
This, definitely. A plunger is likely to either fail to remove the blockage, spray you with filth or both.
