It has been asked for and well I will start one.
Feel free to post your discussions as a AMD 7990 owner here.
I bought one of the Sapphire AMD 7990 the day after OC released them and managed to get the discount at the time 5% or so if I remember, but worked out at £849 from OC. Had some bad problems with overheating which turned out to be 2 of the fans not working. OC were great and a trip to the shop and I was replaced and running.
My findings
Under air I can get mine O/C to 1130 CPU and 1750 MEM which isn't too bad considering this is across both GPU's on the same card. I have yet to push it under water, but once the new case and rads turn up I will post the results.
Post your names to this thread if you want to be added to the 1st post of 7990 owners and I will update accordingly.
7990 Members
Catanonia 1x AMD Sapphire 7990
JRodaga2k5 1 x AMD 7990
Lerun 1 x AMD Sapphire 7990
Diagro 1 x AMD Sapphire 7990
My findings
- I found the card to be very long, just fits in my old Antec case.
- For gaming, the card hardly breaks sweat, but when you push this beast as I do with mining, it runs VERY hot. 90 - 95 on autofans. So during mining I had the fans on 100% and it is fairly loud. Probably quieter than 2x7970's but still quite loud.
- Mining, I was getting 720kh/s with temps just under 91 and I was not going to push it harder.
- Now I am under water, I am getting 772 on each core and temps in the low 60's. Soon going to swap case and add more rad space to get that right down and push past the 800kh/s on each core running max of 375watts. Not too bad. But I would not buy this card for mining alone, great if you have one for gaming as well.
- As for gaming, well every game I run is full IPS 1440 mode with everything maxxed out and no problems, 65 is the highest I have seen on the card air cooled and 50 on water. Again need more rad space.
- It runs hot when you max each GPU for prolonged periods.
- When taking apart, the fan connectors are stupidly placed under the cooling pipes and are a pain in the butt to connect back up.
- Price : Expensive, but it is a prenium product and you pay the price.
- Support : Only certain O/C software works with the card, ie beta AB that allows voltage change. Even Sapphires own TRIXX doesn't recognise the card
- Drivers : Setting the voltage is hit and miss and usually requires 2 or 3 attempts with AB. I check with GPUID to ensure it is set.
7990 Members
