Do you feel the desktop PC is dead, should I sell my PC now and buy a PS4 instead? Might save me a couple of quid on watercooling mind you!!
Windows 8 by any admission is currently a flop. Whatever about the consumer market, large corporates are buying PC's with Windows 8 installed and imaging they back to Windows 7 and I can't blame them having used windows 8 for about a month now.
Why deploy/inflict an OS on a user base that turns up to work and goes OMG! WTF! is this pile of steaming turds and the IT Department's reply is "Well you will get used to it" in the meantime here is a packet of boiled sweets so you can "Suck it up"
MS screwed up and people voted with their feet plain and simple. I think MS wanted to create a tablet OS, which is fine but they shouldn't have forced it onto the desktop environment where it doesn't work this was their mistake, MS are confused. They have created an OS for the Surface tablet and I'm sure its not all that bad (I haven't used it) but they should have also developed a desktop OS.
I can see why they want a unified platform for the likes of XBOX, PC & Surface as it is cheaper to develop and perhaps Windows 8 is the first step along the road, but one size doesn't necessarily fit all. If they do decide on a one size fits all they could be looking at a very bloated OS full of crap you might never use due to the device your using as it won't be optimised.
Interesting times ahead for MS, might be an opportunity to pick up some cheap MS shares
