Permabanned
- 19 Jul 2012
- Buckinghamshire
Yes my braided cable and fan controller came. I'll do my build in the morning
Trying to decide what will be best for coolingVery happy with mine so far, although ive not had chance to test it properlyTrying to decide what will be best for cooling
i have H100i with 4xSP120 performance PWM set in the top as exhaust
3x SP 120 quiet PWM on the front all blowing in.
and a AF140 on the back currently set to exhaust but im wondering if it would be better to have it blowing in also.
what have other people using air cooling done ?
Simon do us a favour and show us your front dust filter in here: http://forums.overclockers.co.uk/showthread.php?t=18531117
Get it out for the lads !!
Big let down, thank god I had my H80i for back up.
My build done. I had to use my H80i because the brand new H100i was broken when I opened it up. It's been sitting in it's box unopened then 28 days waiting for this case. I opened it up and the pump was brokeBig let down, thank god I had my H80i for back up.
Build looks very sweet. I have the NZXT Hue and the lights are great. Their not that bright either. This case rocks![]()
I think I'm going to have to invest in the Hue! Shame I didn't get it when it was £5 cheaper.
Just recieved my case today and found a problem straight away.
Their very own AF140 fans wont fit in the rear of the case due to the rubber mounts, it's only a few mm but I really dont fancy cutting or bending something on my new PC or forcing the holes to line up. damn you Corsair I wanted the coloured rings on my rear 140.
I managed to get a AF140 in. I had to force it a little, but its only forcing the rubber and it works fine.
