- 11 Aug 2012
- S.E Wales
Understatement.
True, Apologises.
Understatement.
Understatement.
True, Apologises.
Why not remove HDD cage if your not using it m8
Source of the windowed Cosmos II?
Believe it's riveted in and therefore would take an 1/8" drill bit to remove (IIRC)
So, decided to downsize so I could have my case on the desk, so went with an MATX Haswell build in the end ... Decided I wanted the G1 Sniper M5 which unfortunately had lime green PCI-E slots and a few other bits, so ended up rattle can painting the "white" rings that came with the SP/AF fans so match ... don't think it came out too bad in the end.
I need to ditch the H100i cables asap and a general tidy up inside!
Youve done a very nice job with the cables tbh. Looks nice and un cluttered and nothing to block airflow. If the psu cables were braided it would really set it off.My modest build and terrible attempt at cable tidying:
Core i5 2400 | Gigabyte Z68AP-D3 | 16GB DDR3-1600 | Crossfire 2GB 7850s
Silverstone Argon A01 | Samsung 830 128GB SSD | 256GB and 500GB Samsung 7200RPM
Aerocool X-Predator X3 with 200mm front and top fans, side and rear 140mm Deepcool UF-140s
Tbh TwsT, i think it looks grand as it is cable wise. Makes the tubing stand out very nicely. Green cables would detract from the look imo.Superb job
Those fans make me want to change mine!!!!!
Took a close up of the inside of mine this morning whilst i decide what I want to do to it.
Think your fans would be a good choice
Really temped by the corsair PSU with green braided cables
Also debating swapping out the top SR1 for a stealth so I can have my fans back.
Or the alternative is put the side panel on and stop wasting money!!!!!!
Thanks!Youve done a very nice job with the cables tbh. Looks nice and un cluttered and nothing to block airflow. If the psu cables were braided it would really set it off.![]()
I left it there with the intention of getting a 1Tb for storage but I am finding I can manage fine with a 256Gb SSD and online storage.
I just checked and the cage is held in by 4 screws that can be removed from the underside of the case. I may do that when I get a couple of new fans for the front.
Really tempted to get rid of my Haf X for the corsair 540, I really like them.
