Sky Updated Epg
18 Oct 2002
Anyone else find that evverytime they update the software it ends up locking the sky box? had to hard restart the thing this morning.
Caporegime
21 Jun 2006
As far as I'm aware the non-recording boxes don't have broadband access (on older kit) or it's not enabled on the new HD non-plus boxes
are you even reading what I have typed?
I have TWO sky + HD boxes
both are connected to the sky hub.
if I had 1 box it would be fine to do callbacks through the hub, but since I have 2 it is not okay.
that doesn't make any sense.
18 Oct 2002
South Manchester
Yes. No need to get aggressive.
My point still stands. Most Multiroom setups have a Sky+HD and a non-recording box. The non-recording box needs connection to a phone line to report back box office purchases etc. as it doesn't support broadband.
It makes perfect sense. The whole world isn't out to get you. There's a few other billion people in it as well.
V F
V F
13 Aug 2003
UK
The only problem I had was failed recordings. First problem I've encountered with updates.
Caporegime
17 Jul 2010
Because the callback for single boxes is for box office and PPV stuff, not to verify location.
Kol
Kol
Man of Honour
8 Jan 2003
Ashby-de-la-Zouch
I understand what Psycho is saying though. You should be able to use broadband for location of both boxes, not just single, because it's the same theory.
Phone line multi room - same landline. If number mismatch, rumbled.
Broadband multi room - same IP for both boxes. If IP mismatch, rumbled.
Edit - sorry, just read your post Misschief. Maybe my point could be implemented one day...
