Sky Updated Epg
Anyone else find that evverytime they update the software it ends up locking the sky box? had to hard restart the thing this morning.
No but mine started to update itself and I wondered what the hell was going on, no warning nothing, I thought it had crashed until it turned back on again and told me what had happened.
Has anyone with an old Pace TDS850 had any epg update yet, i.e. the one with the HDMI dolby update for starters?
From the link I posted above:
Box versions beginning with 4E30 are Thomson boxes and, unfortunately, we no longer update this model.
So the Pace TDS850 *will* be getting the HDMI dolby update eventually. It's there in Sky black and white, nice.
More than one box is multiroom!
If a box is within the inital contract period it should be connected to a phone line IIRC.
As far as I'm aware the non-recording boxes don't have broadband access (on older kit) or it's not enabled on the new HD non-plus boxes
are you even reading what I have typed?
I have TWO sky + HD boxes
both are connected to the sky hub.
if I had 1 box it would be fine to do callbacks through the hub, but since I have 2 it is not okay.
that doesn't make any sense.
Yes. No need to get aggressive.
My point still stands. Most Multiroom setups have a Sky+HD and a non-recording box. The non-recording box needs connection to a phone line to report back box office purchases etc. as it doesn't support broadband.
It makes perfect sense. The whole world isn't out to get you. There's a few other billion people in it as well.
The only problem I had was failed recordings. First problem I've encountered with updates.
Because the callback for single boxes is for box office and PPV stuff, not to verify location.
I understand what Psycho is saying though. You should be able to use broadband for location of both boxes, not just single, because it's the same theory.
Phone line multi room - same landline. If number mismatch, rumbled.
Broadband multi room - same IP for both boxes. If IP mismatch, rumbled.
Edit - sorry, just read your post Misschief. Maybe my point could be implemented one day...
