- 12 May 2004
- England
Big jump up from 5850?
Has the eta just slipped from the 5th to the 6th or is it just me?
Not that it really matters.
It is more like just x2~x2.2, not triple.Yes. x2-3 the speed.
How we all wish it really was tripling the speed of the 5850, but the performance gain over the last few gens had been at too slow a pace. Taking both sides nearly 4 years to double 5850's performance at £200 price point is less than impressive to be honest...both the GTX670 and 7950 should had been at this price point at at least 1 year ago.
While this is a good price for a GTX670, as someone already mention it's nowhere compariable to the "crazy OMG GTX480 deal" back at £200 back then. You'd thought you'd be getting a GTX680 instead of a GTX670 at this price by now![]()
(Not that we are complaining)Yea but it ain't the top card from the last gen like the GTX480 wasI think this deal is just as good as the GTX 480, as the GTX 670 has a few advantages over the GTX 480 that will make it more accessible.
I'm going to order one these now I have decided just for sli as I already have one.
But at the moment I am only running a 60hz monitor so would 2x msi 670 in sli getting 100 min age in most games be point less? or would it best to buy another monitor that supports 144hz ect?
If you're getting over 60fps in all the games you play, it might be better to hold out for an upgrade. On one 670 though you won't get near 60fps in some recent games at max settings, e.g. Tomb Raider, Bioshock Infinite, Crysis 3.
My single msi gtx 670 pe oc get an average of 54.2 FPS on max settings on tomb raider.
That is why I asked if I put a second msi 670 for sli would I need to get a 120/144hz monitor? to fully use them?
Very true mate, crysis 3 on a single 670 is a laggy mess. Ive only played it briefly on my sli setup. Auto sets to very high, even then it fairly taxes both cards.If you're getting over 60fps in all the games you play, it might be better to hold out for an upgrade. On one 670 though you won't get near 60fps in some recent games at max settings, e.g. Tomb Raider, Bioshock Infinite, Crysis 3.
I use to have a Q6600 running at 3.60GHz, and even at that speed, my 5850 (around twice the speed of the GTS250) was frequently getting bottlenecked, in many games with GPU usage dipping down to only 60-80% range, and frame rate dropping to 20-25fps. After upgrading to my i5 2500K (and overclocked), the GPU usage hardly ever dip below 99% anymore, except for Guild Wars 2 (which is insanely CPU intensive is some parts i.e. 40 people fighting dragon plus its minions).my system which i got built from ocuk a good few years ago
q6600 @ 2.4ghz (i have a 3.31ghz oc in bios but my tuniq tower 120 is abit old now and i dont trust it so i use stock ghz
4gb ram
250gts 1gb (my 8800gtx died)
antec 900 case
abit ip35 pro
1000w ocz psu with a tiny loud ass fan
a few questions
1. how big of a jump would this card be from a 250gts even at stock cpu speed
2. will the card fit in a antec 900 case
3. will there be much of a bottleneck?
and a final question if i may
since my pc was prebuilt by ocuk and the cpu cooler being a tuniq tower 120 how easy would this be to remove and replace? does it have a special backplate or anything or can i simply clip a new cpu cooler on? and would i need to remove the motherboard to do this? as i dont think i could manage this
thanks all
FXAA isn't max settings - if you put regular AA on it'll fall massively.
see what happens
