Yeah I use it with a clutch mech, but I went out on a ride with the chainring, before I put the mech on, and I had no drops. Though the chain still slapped around all over. One makes the chain stay put, one get's rid of stupid annoying noises.![]()
On a side note it looks like I'm going to be getting a bit keen with Strava or something like in the very near future managed to get both a Garmin Edge 500 and Motoactv smart watch unit for £25 and £20 respectively!
How'd you manage that? I've been looking for a cheap Garmin Edge for a while now, but even second hand ones seem to go for stupid prices!![]()
so easily could have been an epic fail rather than an epic win
Complain directly to boardman and link your post on here , do the same with halfords customer services online and tell them if they won;t sort it you will go to all the big bike forums and post the pictures and your experiences, you might even want to find the post boardman did on whatever bike forum and post a reply to him and hope he gets an email notification. EDIT! heres the link it was way back in 2009 even... halfords clearly didn;t get the message http://www.bikeradar.com/forums/viewtopic.php?t=12629742need some help with identifying an odd bolt that keeps coming loose - it is through the rear chainstay pivot of my boardman fs. halfrauds instore have been quite frankly useless. i've tried threadlock but it keeps working loose and then the rear of the bike feels odd - i had to wrap duct tape round the bolt to stop it from dropping out completely. i can't even work out the name of this type of screw/bolt/coupling to try and source a replacement
the larger female portion is inboard and takes an 8mm allen key and the smaller male screw portion goes outboard and takes a 4mm allen key
hopefully some pics below (sorry about the focus - new macro lens i haven't quite worked out yet)
Arknor that is a major reaction to something, granted store experience might not have been great, best bet is to of course check the bearings and see what is actually causing the issue. Encephalopathy will get the best response by contacting customer services directly and raising the issue there.
but he shouldn't have to which is the point it shoudl be properly setup and road safe and it clearly is not if that bolt keeps coming loose and making the rear end of the bike feel funny.
how can halfords not do everything in their power to help him and just fob him off?
