True but browns have a bump.I'm using reds their perfectly fine for me. Their no different in speed or accuracy compared to browns.
UK layout keyboards have the small left shift.
You'd have to get a US layout for the big one.
Another one to add to the mix being the Filco Majestouch series of boards...
Recently bought this from QWERKeys, and coupled it with my Breaking Bad set from Tech keys (with my more favoured of the two elements).
I find both MX White and MX Green far too stiff, Black/Blue/Brown being fine, reds too light. And Clears are perfect!![]()
You can get O-ring dampeners to lower the noise or get brown/black switches which tend to be quieter.Any 'quieter' ones around or is it just a no go if i want somewhat silent typing?
