Getting iOS7 onto my iphone :)
this is bizzare. my phone flashed up this morning telling me i can grab a software update. when i go into the settings theres the little 1 hovering beside it letting me know. when i go into software update. it says its update to date. however my when googling my version info in About it says 11A4414e, which is Beta 3. so I'm 2 behind ?
That is bizzare
When did you last update?
Normally the betas expire after a certain date and I would have thought that has passed for beta 3 by now
You might be best downloading and installing again
I have two devices on iOS 7, one registered developer and one not and neither have had this issue. Both update no trouble so this is odd
Anyone else having issues seeing embedded videos on beta 5?
I've just been browsing the motors section on here and none of the embedded videos show?
Decided to give it a go now its reported that Twitter app works properly yet it isnt for me :( the controls along the bottom dont respond to touch at all, same for everyone else?
Other then that, liking iOS7 :D
i tried to re-install but im still having issues with the navigation down the bottom :/
I just wanted to say, THANKYOU:D
I know sometimes repeating stuff in threads is tiresome but i have read this whole thread top to bottom until i got to this post, and after previous failed attempts to install any of the IOS7 betas, I actually now have IOS7 beta5 installed on my phone thanks to you, and although im sure i will stumble across some bugs, im just happy to be in a position to have said bugs installed :p
alright guys, trying to install this on my ip5
the iPhone 5 (Model A1429) File is a .dmg but itunes is looking for a .ispw file??
anyhelp
thanks
anyhelp
thanks
Open the .dmg and the .ipsw file should be inside
I installed iOS 7 beta 5 onto my iPad 3 and suffice to say it is pretty buggy and slow in comparison to my experience with iOS 7 on iPhone 5...
I didn't use any external programs - just opened the .dmg and dragged out the .ipsw file... Not sure if I got some special .dmg file but I've never had to use any extraction software to get them out...
Are you using a mac? That might be why
Does ios 7 increase/decrease battery life at all? Im think ill stick to ios6 unless there are added features in 7
Apart from radio what else does it add? I guess there is an unofficial page with added features somewhere
