Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
That psu is going to steal the air from the left fan on that bottom card. I would turn the psu around if it was me.
hey guys, just gonna chip in on this thread too, I purchased the MSI GTX 670 Power Edition (OC version) for £200 a few weeks back, here are some test results from my card:
Only benchmark program I really have is 3DMark, I ran the Firestrike test.
Highest core clock = 1241 MHz
Highest memory clock = 3005 MHz
Max fan speed = 45%
Max temp = 61°C
ASIC quality = 88.9%
this is all at stock settings, I haven't overclocked anything manually.
How do these figures compare the the £160 "non-OC" versions of the card..?
No bad feedback it's a brilliant card but I am a bit miffed that it's not clocking or is it? Look in my above post.
Still weird I didn't get a manual or install CD though.
Just cleaned up my drivers with driver sweeper and re-installed all the Nvidia drivers and now both my cards are boosting to 1255 on the core. Memory is stock.
Very happy with that. Will test some more over the weekend.
Thats with raising the core offset? How much did you raise it by?
You have a good one. good asic quality and great stock boost.
mine boosts to only 1150mhz without any overclocking and won't overclok any further. Some of these non OC versions are managing that.
So i paid £38 more for.....nothing. Its going back or i want the difference refunded to be honest.
If i had yours i would keep it. You could probably push it a bit further.
No mate thats stock drivers only installed. Have yet to install OC software again but tbh I doubt I will bother as more than happy with the clocks.
and this is with the £160 cards, right..?
£161 Gibbo special from yesterday. Remember anything over stated OC is not guaranteed. The silicon lottery has had me a few times but this time I seem to have done ok with CPU and GPU's..
leaves a bad taste in the mouth.
How have they gone from boosting to 1100mhz at stock to now 1255mhz at stock?Drivers are not going to change their kepler boost value.
Not really anything to do with the silicon lottery. We are talking about out of the box speeds here. Why should a customer who buys the more expensive "overclocked" version have a less powerful card that doesnt actually boost as high? So essentially a worse card for £40....
It isnt right.
It isnt right.
If you are not happy post in the CS section and see what can be done.
