Unigine Heaven 4 benchmark
I reinstalled some drivers and got it up to ~670.
My Phenom II 1055T @ 3.8GHz got higher than this, so I can't believe the CPU is holding it back. Afterburner seems to show 99% GPU usage.
I can't think why this would be working worse unless there's been some Windows update that's done something (or maybe there's another driver doing it?)
4770k - 4.8
670 SLI - 1228/1764
i5 2500k @ 4.5Ghz
MSI GTX 780 Lightning @ 1158mhz Core (Boost to 1332mhz) and 1630mhz Memory
[/URL][/IMG]
This is on stock LN2 bios. At 1.2v and 109% Power limit. Only hitting 62c @ 75% fan speed. ASIC quality 82.3%
Is Sky bios the best modified one to use and what does it actually change? Or has anyone got a sneaky copy of the MSI official 300% bios?
Also how can I increase voltage more than +37mv? The card is begging for some more volts :P Seems a shame a card like this is so tied down, I'm sure is has a bit more to give?
i5 2500k @ 4.5Ghz
I'm using the Sky bios, but I think the standard LN2 is not much different.
The only way I could get more voltage was to use EVGA Precision X software. That gives me the option of 1.212v (that maybe because I have the Sky Bios though).
The 300% bios is nowhere to be found. If it was out there i'm sure it would have appeared to download.
What does the LN2 bios actually change? As all the limits seem the same on both LN2 and stock bios (109% Power Limit, +37mv - 1.2v)
I haven't tested the card a lot yet as I seem to be living at work just lately :( But from quick testing it seems I may be able to push the card a little more on the stock bios rather than the LN2 :confused:
Just seems LN2 bios doesn't change anything, unless I'm missing something or the benefits are only really seen when under extreme cold?
What's the maximum power limit on the sky bios? Still 109%?
