Unigine Heaven 4 benchmark
i5 2500k @ 4.5Ghz
MSI GTX 780 Lightning @ 1158mhz Core (Boost to 1332mhz) and 1630mhz Memory
This is on stock LN2 bios. At 1.2v and 109% Power limit. Only hitting 62c @ 75% fan speed. ASIC quality 82.3%
Is Sky bios the best modified one to use and what does it actually change? Or has anyone got a sneaky copy of the MSI official 300% bios?
Also how can I increase voltage more than +37mv? The card is begging for some more volts :P Seems a shame a card like this is so tied down, I'm sure is has a bit more to give?
Scoreboard updated.:)
Update bench.
Same overclock and cpu clock as before. So stats still:
+52 on the core and +200 on the mem to get me
core - 1201mhz
mem - 1603
cpu still i5 3570k at 4ghz.
I only just updated the drivers from 314.22 to 326.80 with a clean install of drivers with driver sweeper and DDU.
Quite a marked improvment compared to 314.22 drivers. I did think i was been held back a lot by using old but considered rock solid 314.22 drivers. Just figured with the nvidia drivers thread ppl are liking the new beta drivers i thought id try em out.
Update bench.
And on the scoreboard.:)
I'm so tempted to get a 4770k just for score... but that will mean a new mobo also and if i do that it will be a matx case and a big ordeal.
I know you need an in bench shot to go on the score board, but just checking at the moment. Does this seem like a reasonable score?
4770K stock
780 Stock
16GB 2133Mhz
Well it's the second lowest 780. I don't know if you have overclocked it? But hey its only 780s and titans above you so it can't be too bad Hey?
New entry from Gregster
CPU was at 5Ghz for all tests and GPU was at 1346Mhz and 1876Mhz
@ Kaap
Would you be happy to add 1440 to this bench as there are quite a few with this resolution? :)
Amen. All the cool dudes of ocuk are using this res. Right? :D
I will start two new resolutions 1440p and 1600p:D:)
Gentlemen start posting, same settings as before.:)
Quality: Ultra
Tessellation: Extreme
8xAA Fullscreen
@1440p or 1600p
