- 21 Apr 2007
My bundle has to go back tomorrow to get some new RAM installed, but I couldn't help a little test using the Gigabyte z87x-oc as well, but the standard kingston RAM....
Without changing the default voltage of 1.306v (according to the BIOS readings), running the AIDA 64 stability test and an air cooler reaching around 65-68 degrees 4.8GHz was not a problem. 5GHz was a problem that would need more volts or tweaks elsewhere but there is room to play a lot of room
Certainly very tempting. I don't suppose anyone knows if you can get them without the RAM? The only hitch is my existing H100 cooler supposedly not being good enough although I'd have thought if you stick the 4.6Ghz clock and don't do anything stupid you'd be OK (running stress tests for hours on end is not my idea of a good time! As long as it doesn't crash in game it's good enough for me)
Surprised they didn't give you a golden chip!
