- 21 Apr 2007
My bundle has to go back tomorrow to get some new RAM installed, but I couldn't help a little test using the Gigabyte z87x-oc as well, but the standard kingston RAM....
Without changing the default voltage of 1.306v (according to the BIOS readings), running the AIDA 64 stability test and an air cooler reaching around 65-68 degrees 4.8GHz was not a problem. 5GHz was a problem that would need more volts or tweaks elsewhere but there is room to play a lot of room
