I may be in the position of buying one of these bundles in a month, im a networking student who has to use oracle VM at home, nothing fancy just normally one server and one client has anyone tried oracle or something similar on these?
Hi Fred,
Glad your sorted but I am already on balanced, and mine does not step down. As this is not a fresh install after the change of mobo I may well try setting power plan to high performance and then re set to balanced and see if that does it. Might try the backup bios if not. Which bios are you running the standard or X bios?
Edit - have now solved half the problem by re setting power plan - cpu now steps down to 800Mghz at idle as it should, but the v core stays at 1.31 the overclock voltage. Anyone know how to get the voltage to step down?
Have tried enabling c states, but no go?????
Mark
To get voltage to drop you need to set the voltage as offset rather then a static voltage, iirc you find the vid value then set +/- of that for the desired voltage, it should then raise and lower with speedstep.
Do you com to Dundee often so I can rob your expertise lol
Hi Pgi,
Thanks for that - have checked my vid value which appears to be .8250V, does that seem about right to you - not used to haswell yet lol. Btw have you tried the latest x bios vers X05v2 ? I am using X02 at the moment which was suggested to me by a certain gent at ocers.
Mark
one thing pgi what cooling do you use I notice on the options it says if you want the block you must have a descent cooling set up I have a OCUK V8 water cooling kit with the blackice sr1 upgrade ( I also replaced the corsair fans with GT 1850 rpm do you think this will suffice as adaquit cooling?)
Be opening the thread shortly while I finalise a few things, like finally finding someone who has stock of the gpu block I need and do I want to put the motherboard under water
I've gotten as far as taking the case out of the box for a look then put it back in
Same here with vid on coretemp, also some info missing on coretemp as well. Version 1.0 RC5. Will download the latest and check with it.Hi Pgi,
Mark
Pull ya finger out
Done
No pics in it yet, still trying to figure out my mrs camera that I bought her for her birthday last year, that still hasn't been used!
I may be wrong, but there should be a button on top to press
