Completed the first chapter last night. I can't wait to run through this game on the top difficulties and 100% all the levels haha.
So now the game properly begins. And I won't be able to play it again until Sunday
Edit, for those new to the game, the first and most important skills to unlock/use are:
Downward Punch (300 EXP) - If you are airborne with an enemy in the air nearby, press the [given] button to blast it down to the floor below you.
Flying Kick (200 EXP) - Press the [given] button while airborne to grab an enemy and launch into them with a downward kick. This attack only works on larger enemies.
Rising Assault (Free) - This area attack will lift up all surrounding smaller enemies, allowing additional attacks to be combined with it.
Rising Strike (Free) - This direct attack will lift up smaller enemies in front of you, allowing additional attacks to be combined with it.
Somersault (Free) - While blocking ([given] button) use the jump button ([given button]) to leap over and land behind an enemy.
Air Grab (200 EXP) - Press the [given] button while airborne to grab an enemy and pull them into the air. Combine this with further aerial attacks to extend the combo. This attack only works on smaller enemies.
These combined open up a lot more variation into early game combat, mostly air as you can see. But you can really start to string stuff together. Such as if you are surrounded by 3 or 4 enemies. Such as the little goblin guys in the swamps, with one throwing bombs. Use the ariel combo and then jump. It sweeps them all in and drags them up to you, then you can unleash fury. Then the air grab comes in handy to stay in the air away from main combat.
Don't forget to block and roll!!! You will last a lot longer.
A couple of people I know said combat is boring but you really have to use the moves together to get the most out of the combat. It works brilliantly
