Where are you buying this game so cheap? I can't see it anywhere for less than £20?
http://mtrace.greenmangaming.com/u/nrd.php?p=a7NyRJnVjP_696_189304_715_357
Use this code for 27% off, puts it down to £14.60.
TAREM-FGS46-GFS85
I had £2.00 GMG credit for some reason (no clue why) so I used that and got it for £12.60.
Won't let me make a character on Odin![]()
I keep getting disconnected from the server, is that a common issue or something on my end? Can go 30+ minutes between disconnects but it keeps happening.
Well I had the game for a couple of days now and I'm not sure I like it...I find the map quite confusing to use. never played a FF game before so that might be it.
Started as a Maurader and now stuck on a level 5 quest, not sure if it's a main, story or whatever quest - have to rescue a boy from these crab things, just not enough tank to survive the waves that come at you...so I just die and get transported back to town
Anyway have 30days to see how things go.
Indie thanks for the advice - yes going to have to level up for this quest - but it did say that at level 9 I'd be synced or something like that?
Regards
You can change tab targeting in the options and I highly recommend you do (there's one list of things it will switch target to for in combat and out of) because by default it includes a whole bunch of rubbish like pets etc... so PS3 users have some way of targeting.
Storyline quests have a boarder around the circle (looks like it's on fire... ish), you can see this in the quest log (j) or on the objective.
Anyway to nimdok: how to get in contact? is there something like a whisper? or does that come when level 10 or something?
That used to be a problem before all the patches, but I've not heard of it since, I played last night for a good 2 hours without interruption.
Is anyone disconnecting? Never had this problem with any mmo before, seems to be server stability issue but dunno.
