Permabanned
- 15 Apr 2010
I don't have any real fram rate issues to speak of apart from flying a helicopter around central London with the Orbx scenery & every slider maxed.
I'm running Windows 7 64bit
Core I5 3570K @ 4.4GHz
Radeon HD7950
8GB RAM
All on an Asus P8Z77-V Motherboard
It will be fine for about 5 minutes, then a glitch will shoot out of the ground & it gets rapidly worse until I can't even see where i'm flying.
I'll play with the settings some more.
Sounds like classic FSX VAS...also referred to as OOM (out of memory), basically you are asking too much from FSX within its 32bit constraints.
It's a combined 3Gb limit for system ram and video ram
Greatly reduce or switch off AI traffic / cars / ships
Disable light bloom within FSX
Run water at x1 High (no higher)
Ease back on the autogen density and scenery complexity
Honestly it will not look much different but will run SO much better, you certainly have the system for a good FSX experience; its all about finding the balance
FSS has UK Orbx VFR airports for < £9
