The "New Gear/Willy Waving" thread
14 Mar 2005
Here and There...
BAG UPDATE!
I grabbed myself a Crumpler Jackpack 4000 in the end planning to send it back if it didn't fit my requirements as I could find very little concrete information!
For anyone who is interested yes you can close the bag with a full sized flash vertically in it allthough it is a little tight and the bulge of the hot shoe shows from the outside!
Space is good enough for my 5dmkii with Tamron 28-75mm f2.8 attached, 50mm f1.4 and 85mm f1.8 on top of each other one side and a small compact flash like the 270ex the other. If I want to pack a large flash with the camera and lenses I can squease it in lying accross the top of everything.
The bag is great quality and has a nice look to it that even the wife liked so I'm happy for the money.
7 May 2009
Opinions needed, if you guys dont mind :)
I want to purchase a UWA lens for interior photography and other stuff, should I buy the Canon 10-22mm for £417 brand new with warranty or settle for a cheaper used Sigma or Tokina equivalent for about £260?
14 Mar 2005
Here and There...
If you can afford it the Canon is better I'm no convinced it's double the price better and only you can decide how much you value the improvement.
22 Dec 2011
New pocket cam, its pretty impressive so far, after 2 years on android. Mainly moved for VSCOCAM, which is great app.
22 Dec 2011
It's nice to see what that new colour looks like a bit better.
Yeah, sometimes I think I don't really like it but it depends on the light I think. I've decided now after about a month of everyday use that it is awesome for general use. I can fit all my work stuff and my 5D2+35L in there without really feeling the weight. I've used it on a week long trip to Edinburgh and all day at a wedding as well, its been great so far.
I'm glad I didn't opt to pay more for a less functional bag and get a Billingham.
4 Dec 2002
North Lincolnshire
Can anyone recommend a small camera bag for a leica m9 with a 35mm leica f2 lens on it? Would also like a space for another battery and one more lens also. Suggestions? My crumpler and lowepro aw 200 are both far too large
ajf
ajf
30 Oct 2006
Worcestershire, UK
I've not used the Canon but i've i purchased the Sigma equivelant last year and have found it very good. Sharp, punchy colours, but does vignette a bit at the wide end.
26 Mar 2007
Nottinghamshire
For interiors I'd also look at the Sigma 8-16mm.
While 2mm wider doesn't sound like a lot it makes a massive difference, particularly for things like interiors shots.
25 Jul 2007
Has to be a Billingham since you're shooting a Leica now. ;)
25 Jul 2007
They actually do a bag specifically for Leicas I think. I use a Hadley Pro, fits 2xM bodies, 3x lenses and still has lots of space left for other stuff. The Hadley Small should be good for the minimal kit you've posted up.
