Is nobody the least bit excited that cards are confirmed available WITH BLOCKS on Friday???
No reference cooler ftw.
I think Drunkenmaster should start his own youtube channel, he's obviously so knowledgeable and writes review long posts every time he'd surely make more than that guy bringing in thousands every week right?
Yeah I really don't know, the point being made is the guy in the video is taking the position that AMD have marketed (with all their NDA's) the 290x as a Titan killer than labelled it disappointing as a result.
If the card is or isn't a Titan killer isn't the question at all, it's that AMD have never come close to suggesting it or calling it such. It's making up a hyperbolic view of it, just so you can call it disappointing.
It's like if someone wanted to be down on I dunno, Messi scoring 90 odd goals last year, someone could say "but he said he'd score 120, so 90's a bit crap", which IF Messi said that, would be fine, if not, is just a lie to try and make the 90 itself seem worse by comparison. That is what happened in the review, he literally lied about what AMD have said about the card to infer it's worse than everyone expects.
You’re holding a press event in the near future to discuss your next-generation Radeon series, but what can you tell me right now?
“They’re coming in Q4. I can’t reveal a price point but we’re looking at more traditional enthusiast GPU price points. We’re not targeting a $999 single GPU solution like our competition because we believe not a lot of people have that $999. We normally address what we call the ultra-enthusiast segment with a dual-GPU offering like the 7990. So this next-generation line is targeting more of the enthusiast market versus the ultra-enthusiast one.
“It’s also extremely efficient. [Nvidia's Kepler] GK110 is nearly 30% bigger from a die size point of view. We believe we have the best performance for the die size for the enthusiast GPU.
“Another thing I can tell you is about the process node: this GPU is in 28nm. Some have speculated that it was 20nm and it’s not for a specific reason: At 28nm for an enthusiast GPU, we can achieve higher clock speeds and higher absolute performance.”
Yep respect to EK for turning around those blocks.
Just shows what they can do when they are under the kosh.
Or the new cards are so similar to the last series that very little to no work is needed to produce a new block
Lookie lookie Miss Cookie:
http://www.techpowerup.com/192982/ek-debuts-water-block-for-amd-radeon-r9-290x.html
EK-FC R9-290X - 92,95€
EK-FC R9-290X - Acetal - 94,95€
EK-FC R9-290X - Nickel - 104,95€
EK-FC R9-290X - Acetal+Nickel - 105,95€
EK-FC R9-290X - Nickel (Original CSQ) - 105,95€
EK-FC R9-290X Backplate - Black - 26,38€
.To be clear: if you're talking about a card "killing" another then it's nothing to do with price. Otherwise the 7950 kills any card.
Titan killer means it has to be above 10-15% faster, stock vs stock. If it isn't it isn't a Titan killed. It's on par.
Let me put this titan killer rubbish to bed once and for all.
Sauce
http://www.forbes.com/sites/jasonev...eon-cards-next-gen-consoles-7990-criticism/2/
And on a separate note, what on earth happened with the deleted posts?
Much ado about nothing as usual. Just Mei saying what we all thought.
. I'm intrigued.
