Should be better in a closed case if you have good air flow.
not a chancePlease remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
not a chancenot a chance
Of course they would, sitting outside in still air, hot air accumulates around them.
A well set up case moves the hot air way from the components replacing it with cool air.
really, hot air standing around in a cooler environment?. It did amuse me though. Look up the mechanics of heat moving from hot to cold.
I am not a genius in this department by any stretch of the imagination but feel I have a fair understanding of how to direct air through my case. When I bench hard, I take the side of my case off, as this drops the temps by a couple of degrees.
Then you haven't got good air flow in your case, probably a setup causing positive pressure in the case, what you want it negative pressure so it draws the hot air out and cold air in. its much more efficient as your constantly moving and replacing the air. think of it as sitting in a wind tunnel.
Well I have a fan at the very front of my case sucking air in, which is immediately followed by anothe fan doing the same. At the very bottom of my case, I have 2 fans sitting under a 240 Rad blowing air up through the rad. At the back of my case, I have a fan blowing air out the back and at the top of my case I have a 360 rad with 3 fans on top sucking air out. Not sure where I have gone wrong?
Guys no offence, but your airflow discussion is boring.![]()
Test bench.Humbug, what do you think gets better temps?
A GPU on an open test bench, or a GPU in a case with good airflow?
Hopefully better that GTA 4 with any card.
All joking aside, it should be able to run fine even on 'older' cards like the 7970 and 680, it's a console port and hopefully R* will do a good job with it.
I would have thought open test bench by far
its sucking in air from all around - unless you heat the whole room up I can't imagine the ambient would be hotter than inside a case - its not in still air so to speak as you're kicking air out of the back. So its not like its sucking back in the air thats been heated up
vs inside a case the ambients could be as high as 30C
Test bench.
You haven't done anything wrong, two of your intake fans are cooling down the 240 rad, in turn heating up the air, what then 'cools' down your motherboard and goes through your second rad.
When i had the Switch i had the rear fan as an intake, made a slight difference on longer gaming runs.
Test bench.
Well I find it easier to remove the side of the case and have the temps a couple of degrees lower. When you are smashing more volts through than Zeus at a Lightning convention, those couple of degrees can make all the difference
For day to day gaming, I have no worries.
I used to do the same mate when i was inside a case, ramp all fans to 100% and remove the side!![]()
Now all i have to do is make sure i have a fan on the mobo VRMs and ram! They get so bloody hot without some kind air flowing over them.
