Road Cycling Essentials
Status
Not open for further replies.
My Planet-X winter bundle just arrived, great service again from Planet-X.
Won't be making any more cycling purchases after buying my new bike though
some people on another forum were saying the solar storm battery charger and pack are junk , some people saying their UK charger started to get red hot after a few charges.
http://singletrackworld.com/forum/topic/solar-storm-x2-mid-term-report
so it's better to buy the head unit on it's own and get a battery pack and charger from the guy the first post linked to
brings the total cost to about 60 quid though but at least you know you have a good UK charger and a good battery pack and not some chinese crud that could burn your house down whilst charging
My old charger gets very hot too, so I just make a point of charging it whilst I'm near to it, and never leave it unattended, no fires yet...
Bargain Pearl izumi winter jacket in small/med for £35 instead of £140:
http://www.amazon.co.uk/gp/product/B0071MK596
Good review:
http://www.bikeradar.com/gear/categ...arl-izumi-select-barrier-wxb-jacket-12-45523/
Cheapest elsewhere is £90
Thanks again for the link. Mine arrived promptly at 9am this morning, slightly more relaxed fit than I was expecting with just a thin merino baselayer underneath, but it won't be flapping about anyway, and I can easily put a couple of layers on without it feeling too bulky or tight!
£999. Doesn't have the RS80's though.
There was a choice in the sale, Dura Ace and the alloy rims I've got or Carbon RS80s and Ultegra.
Nice - are you using it with discs or hydraulic calipers?
It's TRP Hylex, which is discs. I hope I'll be able to get them on tonight, but it depends on hose length. If they need cutting down then that means I'm in unknown waters and possibly need a new tool.
For first install I'll be using them stock, but I don't doubt that new pads and rotors will be en route shortly.
I just hope the frame fits after all this.
Status
