- 21 Jul 2005
- Officially least sunny location -Ronskistats
do you think my CPU spikes would dissapear if i changed out the Mobo, Also... As im runnning Windows 7 on an SSD, would i need to re-install windows to get it to work with a new mobo?
More than likely, and yes unless its the same chipset but even then fresh will ensure you experience less issues.
). I found with Metro 2033, which is stupidly hard on CPU/GPUs, on Windows 8 an i5 couldn't provide stutter free performance at all, it was pretty bad. An i7 was fine. In Windows 7, even the i7 at 4.5GHz gave stuttering. The fix was the core unpark thing. This seems to reflect the same as the 8320/50.
