Hi all,
Sorry to hear about your loss
benenhausen!! I really feel for you! I'm sure we've all been there...
A few comments:
1) Do try using some fancy latching+shielded SATA cables - if you aren't already doing so. The bog standard SATA cables can be really crap.
2) Don't let machine get clogged up with dust. That
will eventually lead to hardware failures (component overheating or the air hole filter on your harddisks will get saturated with dust, etc.)... I don't think the Antec 300 has dust filters so you would need to do this cleaning operation more often!!
3) In the future learn from your mistakes. Use some kind of data redundancy. Be it online (e.g.
Jungle Disk or
Dropbox) or a backup harddisk. A backup harddisk is best run offline (i.e. only plugged in when you are actually backing up data - say each week or month). RAIDing together harddisks (for data redundancy) is useless without a very good quality uninterruptable powersupply (UPS). Otherwise a power-spike or brownout can potentially take out >1 drive.
4) To all those people suggesting booting into Linux or using this/that data recovery software...
benenhausen quite clearly said he couldn't see the drive in the BIOS!!
5) Most Seagate drives have a minimum of a 36 month warranty (however OEM drives can carry a 12 month warranty -don't think OcUK sell these hoever!!) However they will take your drive, try to fix it and send you a different refurbished drive (the expiry date on this warranty on this will be the same as your existing drive). All your old data will be lost forever...
6) Data recovery firms will charge you an arm and a leg (plus a head for good measure) to get the data back for you!! I have had a go with the
freezer technique and can't really comment on it.
In my case the drive wasn't damaged by freezing it (but I did let it warm up to room temperature before using it - with a fan blowing over it to avoid condensation buildup). If trying this method you would need a second harddisk to backup all the data to
immediately...
Ideally you would a very tech savvy friend to help you (for a few beers perhaps
). You going to need someone who is able to get 'hands on' with you harddisk...
Bob
