Broke the 19K GFX score![]()
i7 3770k @ 4.8GHz
R9 290x @ 1271/1500
Score P15926
Physics Score 11100
Combined Score 10108
Graphics Score 19044
11.13 Beta V7 drivers
Win 7
http://www.3dmark.com/3dm11/7424256
nice
Is them clocks on air?
i7 3770k @ 4.8GHz
R9 290x @ 1271/1500
Score P15926
Physics Score 11100
Win 7
i7 3770k @ 4.8GHz
R9 290x @ 1271/1500
Score P15926
Physics Score 11100
Win 7
The new AMD performance drivers his tuesday. You'll might be able to take on 8packs score then.
i7 3770k @ 4.8GHz
R9 290x @ 1271/1500
Score P15926
Physics Score 11100
Win 7
Hope they release a performance *nix driver, there valley/heaven scores between nix and windows are ridiculous.
Won't happen im afraid without a redesigned gpu. Those benches just favour Nvidia cards too much because of the extreme tessellation preset. Best off comparing on the 3dmark benchmarks or even more importantly, current demanding games.
AMD's Linux drivers are notoriously pants and they probably aren't able to bypass heavy tessellation via driver cheats like they do with DirectX.
Does anyone know what sort of PSU guideline would you need for one of these cards? With over clocking in mind ofc. Currently have a XFX 650 watt... yes I know XFX have a bad rep on here for their rma but want to know if that will cut it or should I invest in a new one? Its 2 years old too. Thanks!
I'm pulling 400w from the wall in BF4 with an CPU o/c at 4.7
Ahh nice! Have you overclocked your 290x too? Makes me wonder why they recommend at least a 750W PSU for this gfx card.
I have a feeling a memory module is not contacting the heat block correctly and I have read else where that the EK block misses a module.
Can I double up on a thermal pad or will it be too thick?
Edit: Is there anyway of testing that the pads are not touching a memory module with taking apart. If one mem module was over heating would it show on the V temps?
I stuck a 290x in a system that had been rock hard stable for over a year, also changed to Windows 8.1 from 7 at the same time.
Everything is fine, temps are fine, airflow in my case is fine, card seems happy, but every now and again i get a black screen lock-up when gaming, I've seen it in Dishonoured and Battlefield 4 three times now. Every time it was after gaming for ages and ages without a problem, and every time it was during a level transition.
2600k with a mild over-clock (which i turned off, same problem).
Z68 Extreme 4 with latest BIOS (i think).
Antec 1200W PSU
Kingston HyperX Genesis 8GB
Any ideas ?![]()
