- 5 Sep 2011
- Surrey
water is the way forward, but I rarely watercool gpus as I never really know how long I'm going to keep them. CPU is a definite though, wouldn't fancy a 4960x on air
water is the way forward, but I rarely watercool gpus as I never really know how long I'm going to keep them. CPU is a definite though, wouldn't fancy a 4960x on air![]()
What about whilst benching or extended periods of intense gaming?
Fair play and I have been water cooled now for about a year. If I wasn't big into overclocking, I don't think I would go for it again (Buying all the rads/pumps/fittings), as the outlay is expensive but once you have it all, just the block is a good move. If I was just regular over clocking, I would stick with air.
That's what I don't get, people say watercooling is silent yet they have these massive rads with 3 or 4 fans on them? Surely that's louder than a 2 or 3 fan windforce, obviously the cooling is way better on water but it can't exactly be labelled silent can it?
I'm honestly split between this and a 290X. How much faster do you guys think this would be compared to the 290X?
This is where ghetto watercooling comes into play
My Antec 620 Kuhler mod, keeps my 780 at 50c @ 1300mhz, the cooler was only £30+ with the bracket will fit any GPU..
Antec 920 on the 4770K and set for 4.6Ghz. Cheap and does the job![]()
How are the vrm's cooled?
I'm going to have to really go cold turkey not to impulse buy the reference cards.
I've never found water cooling silent, certainly quieter but the main annoyance is always the pump, even when it's isolated it still has an irritating hum/whine.
Will they release a custom cooled version? they didn't for the titan.unless you count the gigabyte
Zia
