Do you mean fastest?
Because the best is out right now.
True, Titans have been out for 9 months and will lose its crown on Thursday
How are the vrm's cooled?
Any hints on pricing yet? Can't believe I'm actually considering it![]()
The brackets holds a fan just above the vrm and mem chips, the 620 mod is really effective and so cheap, def worth it for people with smaller budgets and don't want loud GPU's. I can't hear the Kuhler fans over the case fans, really nice and quiet. Yeah really not want one for noisy PC. I remember back in the day I had a 6990, the noise was unbearable![]()
I'll see your 6990 and raise you a venting blade serverThe brackets holds a fan just above the vrm and mem chips, the 620 mod is really effective and so cheap, def worth it for people with smaller budgets and don't want loud GPU's. I can't hear the Kuhler fans over the case fans, really nice and quiet. Yeah really not want one for noisy PC. I remember back in the day I had a 6990, the noise was unbearable![]()
Strap on 120mm fan normally.
Thanks Boom![]()
$700 dollars has been doing the rounds for the 3gb version.
£701 then, I'm out.
I hope nvidia at least can manage another £50 off of 780's, otherwise a couple of 290's under water is looking the more tempting offer. Another 780 & a pair of blocks is looking close to £600 alone, moving to 290's on water would see me with an extra £100 in my pocket when all is said and done.
NVIDIA won't be budging on price, their cards are flying now and NVIDIA never price match AMD, because they are quieter, have PhysX, 3D Vision and soon G-Sync.
NV prices are now set for the festive period.
Gibbo has said somewhere that nVidia aren't budging any more. The prices are set for the Christmas period now.
EDIT:
LOLA 290 with waterblock comes in at around £400 - that's where the party is at.
The one constant with water cooling is when gaming, that quiet hum stays the same and doesn't ramp up at all like air cooled GPU's do.
Unless you have the fans voltage controlled by the mobo according to CPU temps, then they range from "inaudible" to "quiet hum drowned out by game"![]()
I still can't find that exact link but heres another site that did something similar
Update: Based on your feedback, I took the IceQ X2 cooler off the HIS Radeon R9 280X and stuck it on our R9 290 sample. Cooling was dramatically improved. The FurMark stress test maxed out at 76 degrees while the card never exceeded 63 degrees in Crysis 3 and Battlefield 4. So it seems as expected the board partners will be able to solve the heat issues of the reference card.
http://www.techspot.com/review/736-amd-radeon-r9-290/page8.html
