All boards should perform similarly to the AMD-issued samples seen in reviews. Period.
You guarantee everyone should be able to hit 95c on their cards.
Sounds more like a quick fix driver, not a main release.
Shame they can't do a quick fix driver to fix the cooler they went & put on the cards. Surely they should have known to update the cooler from the 7970 one![]()
Have any of you guys ever had a reference 480? I think everyone should own atleast one in their lifetime then anything that comes out will be far less likely to surprise you with its heat and noise!![]()
They should have gone with something better for the stock cooler but for me it doesn't matter, just spend £50 on a nice aftermarket cooler have a day fitting it and tweaking jobs a goodun.
I'll chip in with official word on this.
Two outlets in hundreds sampled have uniquely reported instances of AMD Radeon R9 290(X) boards purchased in retail that have exhibited an uncharacteristic level of performance variance as compared to press samples issued by AMD. As retail products purchased by almost every other outlet (e.g. Sweclockers) do not demonstrate this phenomenon, we’re working to secure the aberrant board(s) in question for further analysis. In the meantime, we’ve identified areas where variability can be minimized and are working on a driver update which will minimize this variance.
We will be releasing that driver in the next 24 hours to fully correct this behavior by normalizing fan RPMs vs. PWM control. The 290X in Quiet mode should be at 2200RPM, and the 290 should be at 2650RPM. If anyone is seeing fan speeds below that, they are affected by this issue, and the driver will resolve the issue in 24 hours.
//EDIT: All boards should perform similarly to the AMD-issued samples seen in reviews. Period.
Personally I think the whole "boost" situation is totally messed up, I liked it when we had a simple "this card runs at #MHz" then Nvidia started doing "This card is clocked at #MHz but will run faster depending on cooling" and now we have AMD saying "This card will do up to #MHz depending on cooling". They could have at least gone for similar methods so not to confuse the consumer...
Agreed, boost is annoying, just give us a core speed and let the users do the overclocking.
The GTX 780TI needs a response.
No it doesn't. AMD said the Hawaii card targets the 780. The 7990 is aimed at the 780TI. AMD normally target the Ultra enthusiast segment (their words not mine) with a dual gpu and i can't see this being any different. A 7990 will still beat a 780TI for a fraction of the price.![]()
A fraction of the price with an extra sprinkling of occasional xfire compatibility issues meaning sometimes you might be only getting a fraction of the performance![]()
So we have:
280X Vs 770
290 Vs 780
290X Vs Titan
7990 Vs 780Ti
Something seems wrong with that picture![]()
Like it or lump it Greg thats how it is. If you don't like it just blank out the 7990. That's how AMD target it though and have done since the 2900XT.
Nvidia cards use non-deterministic boots,which had a minimum limit of boost frequency and no upper limit in practice. Looking at the last three generations of AMD GPU boost(it was first done on their IGPs),it has a defined upper limit. I actually was talking with one of the staff on Hexus about this last year as it was quite interesting.
People really need to look at the articles from Hardware Canucks,hardware.fr,pcgameshardware and other websites,where they showed the GTX660TI,GTX760 and Geforce Titan having throttling issues with the stock cooling,especially after longer runs,where there were clockspeed drops over time.
This lead to many websites,making pre-warming runs before testing current cards,so they would heat up and is also why some websites attempted to lock the clockspeed at fixed values.
Edit!!
Here are some of the articles:
http://www.hardwarecanucks.com/foru...roundup-asus-evga-gigabyte-galaxy-msi-21.html
http://translate.googleusercontent....s.html&usg=ALkJrhj8G8JD8-Rfoq7gPcX-0XdORhBOyQ
http://translate.google.com/transla...97980/Tests/Test-Geforce-GTX-Titan-1056659/4/
http://translate.google.es/translat...013/nvidia_geforce_gtx_760_im_test/index8.php
Some of the drops over time are quite large.
Hardware Canucks on reference GTX660TI said:This brings whole exercise could bring up some worrying points about benchmarking NVIDIA’s Kepler-based cards in reviews (and charts) where every single FPS counts. Sites benchmarking with a single run or shorter sequences will likely achieve the “best” results rather than realistic performance. Luckily, we have been able to avoid this issue by using four run-throughs of every benchmark, each with somewhat long testing times. We’ll have a full article looking at GeForce Boost and AMD’s equivalent in the coming weeks but for the time being, this is certainly food for thought.
Hardware.fr on Geforce Titan said:As mentioned in the introduction, with Anno 2070 as extreme an example, the GeForce GTX Titan is able to reach its maximum turbo frequency as the GPU does not reach 80 ° C. And it reaches this temperature in all games we tested on a bench bench, with and without additional cooling around the map. If we measure the performance of a traditional way, we would get results more pupils and non-representative of the playing conditions in all our tests.
We had to take the time to observe in detail the behavior of the GTX Titan in each game and on each resolution to make sure we do performance measures in representative conditions.
Here are two examples with Anno 2070 and Battlefield 3 with a rapid test, a test temperature stabilized after 5 minutes and the same test as the latter but with two 120mm fans positioned around the map:
Anno 2070: 75 fps -> 63 fps -> 68 fps
Battlefield 3: 115 fps -> 107 fps -> 114 fps
The drop in performance once the temperature reaches cruising can be considerable. An efficient cooling may partially offset this decline, but are there not a contradiction in having to add noise to compensate for a graphics card is trying to remain discreet at all costs?
It also raises the issue of reliability of performance comparisons that you can read here and there, since this may be the big difference based on test conditions (ventilation card but wait or not temperature rise of the GPU for measurements) between extreme cases the gain is 19% in Anno 2070 and 7.5% in Battlefield 3!
Here are the frequencies that we obtained in practice for two selected scenarios: limited to 889 MHz without additional / card capable of up to 1006 MHz with additional cooling cooling card. 3DMark is only able to maintain the maximum frequency due to loading time between scenes that allow the GPU never have time to reach 80 ° C.
HT4U on reference GTX760 said:It is worth emphasizing that a typical benchmark behavior, immediately after starting the game in all situations almost always has a GPU clock speed of 1137 MHz result. After 15 minutes in a static scene is an entirely different value is emerging, which is on average only in the range of about 1000 MHz and this at 21 ° C room temperature. Thus we see an agent that acts still below the NVIDIA naming of 1032 MHz.
The speed of the fan behavior is interpreted here in a maximum noise level of about 2190 revolutions per minute. After that, then usually provide a further clock reductions, which are also observed in the course of the game that way. The regular course can cause a very different behavior than a static benchmark scene, as used in the present case. The example we have here demonstrated.
pcgameshardware on Geforce Titan said:In summary, we have the GeForce GTX Titanium why shooed in four settings through our course to cover every possible scenario useful:
• Standard method with artificially limited-on the Nvidia "guaranteed" Boost clock rate of 876 MHz. Similarly, we handle it since the GTX 670 These values are also the basis of our tests represent ("@ 876 MHz")
• Free boost development on our open test stand with enough cooler air ('dyn. Boost ")
• Individually applied to the minimum clock rate at 28 ° C inlet air is warm, and after 30 minutes of warm-up phase at constant load in-game map set. This corresponds to the housing operation in summer temperatures ("28 ° C")
And last but not least, we use the OC potential of the map something out, by increasing the offset clock to 100 MHz via EVGA Precision, the Power Target to 105 percent and the target temperature is raised to 85 ° C - all relatively safe levels .
290 Vs 770
290X Vs 780
7990 Vs Titan/780Ti
Sorry Greg, just realised you had it wrong. This is how its supposed to be.
