Jesus, when do people lose all ability to reason.
Custom cooling actually takes time to manufacture, it's that simple. No card I can recall and certainly no big new release has ever had custom cooling on launch so where is the oversight?
3rd party cooled Nvidia cards significantly outperform Nvidia stock cooling, including on Titan, 780, 780ti. The first card with a new core and new PCB gets stock cooling and custom versions always take 6-10weeks, always, absolutely always.... did I mention, always?
The 780ti is not a new core, the 780 wasn't a new core, it's the same core as Titan. The 7970 had no custom cooled cards  for a couple months, neither did the 680gtx, the 580gtx, the 480gtx, the 280gtx, the 5870, the 4870 or anything else. The 280x does because it IS the 7970 and it already had custom coolers out for it and used the same pcb/core.
Hawaii is the first new core since the 7790, which was the first new core since Titan, the 680gtx and the 7970 in order, none of these cards had custom coolers available day one, neither will the next gen AMD/Nvidia cards(I guess gtx880 and R9 390... R10 290, whatever the heck they are doing with that naming scheme
In 6 ish weeks there will be custom cooled versions for anyone that wants them, its the same wait for AMD or Nvidia with new cores.
Titan/780 and likely the 780ti all throttle under gaming on the stock cooler, which people talk up how brilliant it is and how quiet it is.... yet it throttles, So AMD make a quiet mode and it throttles, this is terrible for AMD but fine for Nvidia, they make a loud mode which barely throttles and isn't close to insanely loud, then people turn on the 100% fan and everyone acts like it's the default sound level.
The whole "fine for Nvidia, terrible for AMD" thing is tedious and daft. Third party cooled 780gtx's massively outperform default 780gtx's, they throttle less at stock, they overclock further, they are quieter and the keep the temps down. Why is this fine for Nvidia but AMD make a cooler that has all the exact same attributes(while also not massively overcharging you for the same performance level) and it's terrible?
