I have been reading about this new tech on [H] forums....
Someone took it apart and it has a new sharp 10 bit 120hz VA panel in it.... Apparently AOU are making 24 and 27" 1080p 120hz VA panels as well.... Maybe sharp will release a 27" version....
This is exciting to me because I hate TN screens and although IPS is alright the white glow and contrast is frankly rubbish.... So I think within the next 6-12 months we should be seeing 24" and 27" 120/240hz VA panels..... If a 27" comes out I will be getting that and finally replacing my 20" NEC WGX2 postage stamp... It has served me well for about 7 years! I have always wanted a screen with high contrast ratio, 120hz etc. But I thought this would not happen until OLED comes out, so finally we have some interesting monitors coming out instead of MORE 120hz TN or IPS monitors which are basically exactly the same every year.
The panel is technically 8-bit +FRC but capable of supporting 10-bit colour depth as a result (confirmed with Eizo). Also while AUO did have a couple of 120hz AMVA panels listed back in 2011, I've been told they currently have no plans o produce any. That may change if this Sharp panel takes off perhaps. Not heard of a 27" panel but it wouldn surprise me somewhere down the line
