Is that 3x Eizo foris?
Yep!
I'm seeing a lot of ghosting across the entire screen with or without 240hz mode in Team Fortress 2 and Farcry 3 even at 120fps. Is this normal? The whole screen will ghost up as I turn.
will test thenI can't post any pics sorry. The monitor is packed up and ready to go back. Bluring did not happen so much in BF3/4 but it did happen a little. The above mentioned games however. Wow. So much total screen blurring. Major ghosting across the entire screen until I stopped turning.
On a side note. I have just plugged in my Samsung SA750D again. Wow the colours don't look half bad actually! The blacks are not as good and reflections are a little distracting but I have red back again! Red on this panel compared to the Eizo is much better.
Yep!
Try it with the OMFG updates which have just started arriving. The performance increase is massive for every kind of system, you should be able to get into 3 digits much more regularly.That is a good point, I have two graphics cards and in planetside 2 (not the most optimized game) i am lucky to hit 60fps, if i tweak everything I can push 100-140 depending on situation, is the limit going to be the frame rate, would i be better off with a 1440p?
Now, after reading more and more about this monitor on a few different forums, I am back to been undecided. Eizo make premium monitors, but there seems to be lots of issues with the FG2421.
