For example. This video:
In Chrome, the Chrome helper service shows as 50% CPU in Activity Monitor.
The same video in Safari shows as 10% CPU.
That's just Chrome.
Anyone on the 15" (i7/16GB/750m) had any crashing/freezing issues?
Just had another lock up (5th?) while browsing facebook, got the loading pinwheel thing and then everything just froze.![]()
For those who ordered online, does the package come in unbranded packaging or is it obvious what it is?
Can you specify an alternative delivery address?
It'll come in a square brown box (it's quite obvious there's a laptop inside). UPS will only deliver to your specified address for security reasons and you have to be there to sign for it.
I had considered the Speck cases and am a bit of a speck fan myself as I've always used their cases on my iPhones, however I've seen reports that they crack around the edges after a while? Have you ever noticed this issue at al?
How are people finding the memory usage with things like Photoshop etc? As I'm wondering whether to go 16gb on the 13" model.
Go 16GB. You can't upgrade later remember.
I found 4GB on my MBA was fine for PS CC. Running 8GB now and I can't tell the difference.
can the 15inch macbook pro retina connecto a 24 inch And a 22inch monitor at the same time?
Yes. The 15" rMBP can run up to four displays at the same time - two via Thunderbolt, one via HDMI and it's own display.
I'm still having this dilemma. Does anyone have any examples of where 8GB just isn't enough?
