Benching session starting soon.
haha, i just bought the same psu
why did they make the vga cables red?!
Guys, quick question.
Is there any R9 290 brand that doesn't void the warranty if you put a custom cooler like a Gelid Icy Vision Rev 2?
Yes MSi and Sapphire if bought from OcUK.
Considering that VRM is on the edge of the card facing the case side panel, perhaps a side fan on the panel would do the job?
If your case does not accomodate a side fan then it is easy enough to mod, some double-sided adhesive pads or cable ties or something.
I found this thread which discusses what you want to do: http://forums.overclockers.co.uk/showthread.php?p=22719581 - opinion seems to most of the airflow would be wasted with the edges sticking out beyond the card's edges.
