The Nexus range will never be the best android phones on the market but they are not intended to be.
Got a serious case of deja vu for a second there! Then I realised it's because you posted the exact same thing on the previous page?![]()
Can happen if you flick through your browsing history and load the page where you edit the message again as either this or the action of then leaving the page can trigger the "post this message" action on the forum. I've certainly done this before now!This is a surprise to me aswell, absolutely 0 idea how that happened, I only posted it once and definitely not hours apart.
I don't know about that. What part of that quote do you disagree with? Possibly 'better screen' as that can be down to the individual's prefence, but otherwise most of that quote is probably correct I would say.
I had the original Nexus for 48 months, just picked up a Nexus 5 from CPW.
My original was given a new lease of life on Cyanogenmod. I'll jump on it soon with the N5
sounds like a envious man talking
I thought CM mod was basically for old or crappy phones that wanted to have the latest updates.
With the nexus it should always have the latest updates so why choose that over say another custom ROM?
Let us know when you find the best phone then, it'll save the rest of us some time and money.
The LG G2 is a better phone for one. Why? Because the Nexus 5 is based on it but with slightly cheaper parts to make it fit the price bracket.
So yes, technically the G2 is a better phone.
Technically the iPhone 5S is better too. There are so many technically better phones out there.....
How is the iphone better technically?
apart from the camera I just don't see it.
Full HD screen, bigger screen more pixels, etc.
More RAM, more cores, more battery, etc.
Build quality, better and faster CPU. Better camera, better speaker.....
build quality is arguable is it not?
the nexus 5 feels like it's built pretty well to me.
on another note there is a physical mod you can do to the nexus 5 which even has videos showing you on how to improve the nexus 5 speaker.
basically take the back off, and poke 3-5 holes into a bit of plastic which you unscrew from the chassis.
more holes = more ways for the sound to escape = the whole chassis gets used to amplify the sound outwards.
it's a pretty simple and easy mod to do if you have the correct tools.
also is the CPU in the iphone faster? because the nexus 5 feels faster to me when in use.
therefore you could argue that software is better on the nexus 5
I wasn't making a complicated point, I'm slightly disappointed that you've not understood or ignored it.
The LG G2 and iPhone 5S may be better phones in your view but they're not in mine. The whole package is a subjective thing, you'd do well to stop talking in absolutes.
