Flash ok but absolutely refused to install newest beta drivers
had to go back to original before they would install.
I might try again tomoz but cant think what the problem could be.
W7 btw
If you have multiple monitors unplug them... (worked for me and a friend, I know it's odd and should make no difference).
Use UDD tool to remove existing drivers and then try and install beta.
What happens when you try to install the drivers?
