A Week With NVIDIA's G-SYNC Monitor
Well my query was for playing games, benching was just an example.
I've been holding out for a new monitor for a while now, might just hold out a bit longer for one of these badboys.
the main reason people turn off vsync for playing games is because of input lag - gsync removes input lag so no reason to turn it off, get all the benefits all the time :)
Yeah seems I mis-read, my apologies.
[Edit] Or what Gibbo said. I knew I wasn't imagining it! :p
[Edit2] Gibbo, will these monitors all be TN Film or are there going to be IPS models at launch?
Unfortunately TN by looks of stuff. :(
Which for me is an instant NO.
The only 1920x1080 monitor I'd consider would be a 27" VA or 24" Eizo IPS 240Hz.
To be honest I preferred the image quality 2560x1440 gives in games over 1920x1080 with some gimmick to help smoothen stuff out. Resolution, viewing angles and image quality is KING for me, which means IPS/VA/PLS all the way. I really don't like TN screens. ;)
I switched from an old DGM VA to a XL2411T and the TN panel is driving me crazy. If the DGM wasn't broken I would switch back for desktop and non-gaming use.
Really like my current asus vg236, the only thing is missing from it is lightboost and gsync which I'll get both of when the asus monitors land.
Can you hint on pricing gibbo? As in sub £400 or above?
TBH Lightboost isn't all that good, used it for while then ended up switching it off. The colours and brightness become washed out and the reduced motion blur needs a frame rate to match the hertz so 120hz needs 120fps to get the benefit.
Guru3D's got a write up, he's quoting GBP 445.00 Incl. VAT for the Asus, available next week?
Sorry, that is an absolute joke. That is DELL monitor money which are far superior in image quality.
Infact for £599, buy you a Samsung 27" PLS. Absolutely zero chance, over-priced beyond belief for a 1920x1080 TN panel, what a joke. :(
£450 for a TN?
Way too much, the standard version of that monitor is £299, so £150 for this, shall wait for BenQ, they will give the customer value.
Right now I'd be buying these, all superior IMHO:-
AOC Q2963PM 29" Professional Super-Wide LED Multimedia Monitor - Gunmetal @ £359.99 inc VAT
AOC’s Q2963PM greatly enhances your productivity and experience; work and leisure won’t be the same with features like the ultrawide cinematic screen, screen-splitter function, and dual link-up. Whether it’s for viewing multiple documents, a more immersive movie and gaming experience, or multitasking simplicity, the 29” Ultrawide 21:9 screen monitor gives you what you need.
The AOC 29” UltraWide features an LED Backlit screen that offers brilliant color and ultra clear images. The full HD 1080P Resolution, with 50,000,000:1 contrast ratio and response time of 6ms, creates superior picture sharpness and the In Plane Switching (IPS) Panel allows you to view your spreadsheets or weekend movies from virtually any angle without compromising color uniformity.
The UltraWide is available for multiple full sized applications as an upgrade to dual monitor settings. Enjoy dual monitor productivity on a single screen. The vast panoramic screen is easy on the eyes, and with the screen-splitter function, multitasking has never been so simple.
The AOC 29” UltraWide screen and equipped dual 3 Watt enclosed speakers deliver a more awesome immersive experience for your favorite movies or games. The narrow bezel frame offers a sleek cinema-like screen experience.
The AOC 29” UltraWide’s connectivity is ultra-useful. The HDMI Connections carry high definition picture and sound in one easy cable. The HDMI with MHL allow you to connect your smartphone easily without a network connection. You can stream videos from your phone on to the monitor screen while charging your mobile device at the same time.
The PIP/PBP Hardware Calibration Ready (Dual Link Up) allow two devices to be viewed on the monitor simultaneously. The DisplayPort connection allows you to connect several monitors to your notebook with one simple cable.
The AOC 29” UltraWide is EnergyStar qualified, which means it uses about 30% less energy than standard units. Plus, it has no arsenic in the glass, mercury-free LED, and no BFR/PVC Laminates. It also qualifies for the latest standards such as TCO and Energy Star.
Features:-
- Panoramic screen with screen-splitter function for multitasking ease
- Cinematic Screen with 21:9 Aspect Ratio
- WFHD maximum resolution of 2560 x 1080 @60Hz
- PBP or PIP multitasking function for enjoying an image from two sources at once
- Multimedia connectors for VGA, DVI-D with HDCP, HDMI (MHL), DisplayPort
- Mobile High-Definition Link (MHL) to connect and charge the phone
- IPS Panel with full HD 1080P and an LED backlit screen
Specification:-
- Viewable Image Size: 29" (21:9)
- Brightness (typical): 300 cd/m2
- Contrast Ratio: 50000000:1
- Response Time: 5ms
- Optimum Resolution: 2560 x 1080 @ 60Hz
- Colors Supported: 16 Million
- Inputs: RGB D-Sub, DVI-D, HDMI & DisplayPort
- Built-in Stereo Speakers: Yes / 6W
- ENERGY STAR ? Compliant: Yes
- EPEAT Rated: Yes
- Dimensions (WxHxD): 713.57 x 387.91 x 211.99 mm
- Warranty: 3yr
Only £359.99 inc VAT.
ORDER NOW
Asus PB278Q 27" Professional LED Multimedia Monitor - Black @ £449.99 inc VAT
Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! New premium 16:9 wide-format PB278Q LED displays afford 178° wide viewing angles for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true “what you imagine is what you create” power. HDMI 1.4, DisplayPort 1.2, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
The PB278Q features a 16:9 aspect ratio and a LED-backlit 27” WQHD display that provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals – equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
The screen’s 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PB278Q, power and energy savings are no longer compromised, while better visuals are assured.
The ASUS PB278Q provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27” full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB278Q is undoubtedly your best choice for work and play.
The PB278Q features a host of connectivity options that include HDMI 1.4, DisplayPort 1.2, and dual-link DVI for native WQHD, plus D-sub for full HD 1080p content transmission. Twin built-in 3W speakers provide quality audio for a completely immersive home theater experience.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the PB278Q enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
Driven by a precision color engine that automatically analyzes and determines the nature of your current task, Splendid™ Video Intelligence Technology adjusts display parameters accordingly to ensure color accuracy and image fidelity. Six preset modes (scenery, theater, sRGB, standard, and two user-customizable modes) can be quickly selected via a designated hotkey.
The PB278Q offers a highly ergonomic and smart design that comes with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment.
Features:-
- Stereo Speakers: 3W x2
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" PLS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 8000000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI 1.4, 1x DisplayPort 1.2
- 8-in-1 Card Reader
- VESA Compliant (100x100)
- Dimensions: (WxHxD): 643x552.3x218 mm
- Weight: 8.80kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
- Product Review: http://www.tftcentral.co.uk/reviews/asus_pb278q.htm
Only £449.99 inc VAT.
ORDER NOW
Benq XL2720T 27" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red @ £319.99 inc VAT
The XL2720T demonstrates BenQ's true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming. Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2720T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3. conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by the legendary Counter-Strike players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
Meet your secret winning strategy. The FPS Mode was co-developed with gaming legends to let you tap into the fundamental insights of pro gamers and view the game how a gaming legend would see it. This out-of-the-box preset automatically adjusts your monitor calibrations to provide you with optimal brightness, contrast, sharpness and color tint. Being able to spot your enemies and track their move carefully in every situation put you at an advantage over your opponents.There are two variations to this special mode: the FPS1 mode is designed to configure and optimize the display for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source as recommended by BenQ. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:10), 21.5"W (16:9), 22"W (16:10), 23"W (16:9), 23.6"W (16:10), 24"W (16:9) to 27"W(16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
With a refresh rate of 120Hz, there's never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2720T gives you on-screen action and captivating realism. Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display. Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2720T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy. BenQ professional gaming monitors are not only the official global Tournament monitor of top notch league and tournaments, but also unrivaled victor of world renowned design awards. In addition, BenQ professional gaming monitors are used by prominent gamers to perfect their gameplay.
Specification:-
- Back Light Unit: LED
- LCD Size: 27"W 120HZ
- Aspect Ratio: 16:9
- Resolution (max.): 1920×1080
- Pixel Pitch (mm): 0.311
- Brightness (typ.): 300 cd/?
- Contrast (typ.): 1000:1
- DCR (typ.) (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170 / 160
- Response Time (Tr+Tf) typ: 5ms, 1ms (GtG)
- Display Colors: 16.7 million
- Color Gamut: 72%
- Input Connector: D-sub/DVI-DL/HDMI/DP
- USB Hub: Donwstream x 3, Upstream x 1
- VESA Wall Mounting: 100X100 mm
- Swivel (left/right): 45/45
- Tilt (down/up): -5/20
- High Adjustment (mm): 140 mm
- K-Locker: Yes
- CTN Dimensions (HxWxD mm): 486 X 711 X 245
- Dimensions (HxWxD mm): 548 X 642 X 273
- Dimensions with Wall Mount (HxWxD mm): 485 X 642 X 269
- Net Weight (kg): 7.5
- Gross Weight (kg): 10.2
- Warranty: 2yr
Only £319.99 inc VAT.
ORDER NOW
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey @ £449.99 inc VAT
Cinema-like clarity shines on the expansive 27" DellTM UltraSharp U2713HM monitor. Comfort settings and connectivity options help keep you productive. WQHD resolution and accurate colors out of the box: Superb clarity with 2560 x 1440 resolution and over 3.6 million pixels. Features a color gamut of more than 99-percent sRGB.
Excellent comfort and usability: Full adjustability including swivel, tilt, height adjustability and pivot which lets you easily switch to portrait mode. Eco-friendly design: Compliant with the latest environmental standards and made using environmentally conscious materials
2560x1440 WQHD resolution: Over 3.6 million pixels provide amazing clarity on a spacious 27" LED-backlit display. Easily adjust screen brightness to suit your environment. Accurate color right out of the box: Carefully color calibrated at the factory, the U2713HM monitor features more than 99-percent sRGB color space for impressive color from the moment you set it up. Wide-angle viewing: Uncompromised color consistency across an ultra-wide viewing angle of 178°/178° gives you broad viewing flexibility and lets you collaborate easily.
Full adjustability: Work comfortably and view images from a variety of positions with swivel and tilt. Easily switch to portrait mode with pivot. Set your U2713HM to the optimum height with a height-adjustability range of 115mm. Latest connectivity options: Seamlessly connect your monitor to your desktop, laptop and peripherals such as digital cameras and Blu-ray or DVD players. Digital and analog connections include four USB 3.0 ports, DisplayPort 1.2, DVI (HDCP) and HDMI. Stay productive with Dell Display Manager: This one-stop software tool lets you quickly access applications such as Auto Mode, Easy Arrange and PowerNap. Use Auto Mode to adjust or auto-assign preset modes to specific applications. Use Easy Arrange to neatly tile your applications, arranging them in your preferred layout
Meets latest environmental standards: The U2713HM monitor meets EPEAT® Gold and TCO Certified Displays standards, is ENERGY STAR® qualified and CECP compliant. Made with responsible materials: This monitor is made with arsenic-free glass, a mercury-free panel, uses 25-percent post-consumer recycled plastics in its chassis and BFR/PVC-free laminates in its circuit boards. The U2713HM also ships with environmentally responsible packaging. Helps save resources: Enable PowerNap mode to reduce power consumption by dimming the monitor to minimum brightness or by putting it into sleep mode.
Features:-
- LED Backlit
- Height Adjustable
- Screen Size: 27" IPS Widescreen
- Contrast Ratio: 2,000,000:1
- Brightness: 350cd/m²
- Response Time: 8ms
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI, 1x DisplayPort,
- 5-Port USB3.0 Hub
- VESA Compliant
- Dimensions: 639.3mm (25.17'') x 200.3mm (7.89'') x 424.3mm ~ 538.9mm (21.22'' ~ 16.70'')
- Weight: 10.20kg
ORDER NOW
Dell UltraSharp U2913WM 29" Super-Widescreen LED Monitor - Midnight Grey @ £379.99 inc VAT
Navigate multiple applications at once and multitask like never before. A vast, 29" panoramic display with a 21:9 aspect ratio and 2560 x 1080 Wide Full-HD offers the screen space of side-by-side monitors without a distracting bezel in between. Plus, with a 178°/178° (typical) ultra-wide viewing angle, you can enjoy an excellent view from almost any position.
Experience remarkably precise and accurate color made possible by over 99 percent sRGB at a delta-E of less than 5, offering broad color variation. Plus, the U2913WM comes factory color-calibrated, so you can enjoy outstanding color accuracy right out of the box.
Make it work for you, with extensive connectivity such as DisplayPort 1.2, USB 3.02, Mini DisplayPort, DVI and HDMI, plus highly adjustable tilt and swivel positioning, a 130mm height adjustability range and a VESA-compatible wall mounting option (mounting kit sold separately).
Synchronize your applications and improve your visual experience. Dell Display Manager offers a variety of features that can optimize your media presentation and maximize your monitor’s real estate, such as Easy Arrange and Auto Mode.
Automatically optimize your video settings with the Smart Video Enhance3 feature, optimizing colors and sharpness for the best possible presentation. Choose Movie mode for recommended settings, or choose Advanced mode to manually adjust contrast, sharpness, color saturation and hue however you like.
Stay energy-efficient with PowerNap and dynamic dimming features that automatically help regulate power usage. Plus, the U2913WM features an eco-conscious design with arsenic-free glass, mercury-free LED and BFR/PVC-free laminates in the chassis. The U2913WM is EPEAT® Gold and ENERGY STAR® qualified and comes packed in eco-conscious recyclable packaging.
Specification:-
- Panel: 29-inch (73.02cm( (diagonal) VIS with LED backlights
- 21:9 aspect ratio
- LED Technology
- Response: 8ms
- Resolution: Wide Full-HD 2560 x 1080 at 60 Hz (Max)
- Viewing Angles: 178°/178° ultra-wide viewing angle
- In-plane switching technology
- Color calibration factory report
- More than 99% sRGB (deltaE < 5)
- Input Connections: DisplayPort 1.2 / mini-DisplayPort, DP-out, HDMI, DVI-D (HDCP), VGA
- USB3.0 Hub (4 downstream / 1 upstream)
- Tilt, swivel and height adjustable (130mm)
- Option to wall mount in landscape and portrait mode (VESA 100mm x 100mm)
- Arsenic-free glass and mercury-free LED panel
- Dell Display Manager - Auto mode, PowerNap, Easy Arrange, Smart Video Enhance
- ENERGY STAR®, EPEAT Gold, TCO Certified Displays, ErP Standards compliant
- 3yr Onsite-Warranty
Only £379.99 inc VAT.
ORDER NOW
Iiyama Prolite XB2779QS-S 27" AH-IPS Professional Widescreen LED Monitor - Silver/Black @ £439.99 inc VAT
Featuring WQHD (2560 x 1440) resolution, the XB2779QS can display almost 77% more information on the screen than a Full HD display. Users can create their own workspace by displaying and manipulating multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent colour reproduction, wide viewing angles and a fast response time. An array of inputs including HDMI, DisplayPort, DVI and VGA connections ensures compatibility across a wide range of mulitimedia devices. The XB2779QS is perfect for demanding users who settle only for the best specifications and modern design.
With true WQHD 2560 x 1440p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen, i.e. over 76% more in comparison to a 1920 x 1080 monitor.
The AH-IPS panel technology guarantees consistent colour reproduction with wide viewing angles and high contrast and therefore it is especially recommended for graphics design and other applications which require colours to be displayed accurately. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable for both business and home use.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Specification:-
- Diagonal: 27"
- Panel: AH-IPS LED-backlit
- Display area h x w 335.7 x 596.7 mm; 13.2" x 23.5"
- Response time: 5 ms
- Contrast: 1000:1 typical
- Contrast: 5000000:1 ACR
- Brightness: 350 cd/m² default, 440 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.77 million
- Pixel pitch: h x v 0.233 x 0.233 mm
- Native resolution: 2560 x 1440 ( 3.7 megapixel)
- Horizontal sync 30 - 80 KHz
- Vertical sync 55 - 75 Hz
- Synchronization Separate Sync
- Aspect ratio: 16:9
- Colour range: AdobeRGB: 86%, sRGB: 116%, 82% (NTSC)
- Connections: VGA, DVI-D, HDMI & DisplayPort
- HDCP: Yes
- Dimensions: w x h x d 650 x 435.5 (564.5) x 230 mm
- Weight: 8.2 kg
- Warranty: 3yr
Only £439.99 inc VAT.
ORDER NOW
Samsung S27B970D 27" Widescreen Ultra Thin LED Professional PLS Monitor - Black @ £599.99 inc VAT
The trailblazing big-screen Samsung Series 9 introduces an exceptional generation of monitors, with superior visual advances from the industry’s five-year global market leader. Remarkable resolution and vivid brightness fill the screen edge to edge with the limitless colors of nature, delivering unrivaled picture quality. Set on an elegant base with a sleek frame, the monitor renders intensely rich colors and astonishing detail, even at wide angles. Quite simply, the Series 9 outshines other screens.
Samsung’s exclusive technology automatically calibrates brilliant true-life color, taking the challenge out of choosing a monitor with premium picture quality. The Series 9 relives your memorable moments on the monitor in the vivid detail you remember.
Answering the need for higher resolution and precise detail editing, the Series 9 Monitor showcases extraordinary picture quality without losing any color or perspective, even from ultra-wide angles. Its WQHD technology enables the images to remain ultra-crisp with resolution that’s four times
higher than older conventional HD monitors.
With its slim and gleaming silhouette, the Samsung Series 9 showcases shimmering images that seem to display in mid-air. The crystal clear tempered glass screen enhances both the vivid images and the streamlined design. Innovative LED Touch UI delivers emotionally intimate engagement and satisfying results. Ports are artfully concealed in the back to highlight the stylish brushed aluminum hairline (HL) finish. Simply elegant, the Samsung Series 9 Monitor represents world-class innovation.
Defined by distinctive forward-looking and consumer-friendly design, the Samsung Series 9 Monitor is made for ongoing value. The Series 9 internal performance is as advanced as its striking exterior. Along with sensational good locks, you’ll discover intuitive and exacting technology as well as an ergonomic Height Adjustment Stand (HAS) and tilt for comfortably customized viewing. The Samsung Series 9 offers unequaled simplicity.
Engineered to deliver unparalleled picture quality and consistently accurate all-natural color, the Samsung Series 9 works to make that experience as seamless as possible. Enjoy content from MHL-enabled smartphones and tablets with the benefit of richly displayed images and compelling audio. You also can simultaneously browse on smartphones and even charge devices.
The Samsung Series 9 premium monitor delivers the best in picture quality, style and connectivity. Its exclusive color technology renders vivid content, video, photos and more. This monitor sets the new standard for sophisticated and approachable design, appropriate for any décor. Multimedia connections are easy and seamless for all devices. The Samsung Series 9 will surpass your every expectation.
Specification:-
- Screen finish: Glossy (Reflective)
- Screen Size: 27" / 68cm (16:9)
- Type: PLS LED
- Brightness: 285cd/m (High Bright Mode), 220cd/m (Standard Mode)
- Contrast Ratio: Mega DCR (Static 1000:1)
- Resolution: 2560x1440 (Wide Quad-HD)
- Viewing Angle: 178 / 178
- H/W Calibration Engine
- Connections: Dual Link DVI, DisplayPort, HDMI 1.4
- 2x7W Speakers
- USB Hub
- Dimensions: 645 x 467 x 247mm
- Warranty: 3yr
- Product Review: http://www.expertreviews.co.uk/monitors/1293385/samsung-series-9-s27b970d
- Product Videos: http://www.youtube.com/samsungmonitorglobal; http://www.youtube.com/watch?v=Pn3gsyEKzKQ&noredirect=1
Only £599.99 inc VAT.
ORDER NOW
EIZO Foris FG2421 23.5" 240Hz Widescreen Gaming LED Monitor - Black/Red @ £449.99 inc VAT
Experience fluid gameplay free from motion blur with the gaming industry’s first 240 Hz monitor. EIZO’s Turbo 240 converts 120 Hz input signals to 240 Hz for a refresh rate double that of conventional gaming monitors so you can enjoy the smoothest motion display yet for first-person shooter, racing, and other fast-action genres.
Input lag, or the time it takes for commands from a keyboard, mouse, or controller to appear on the screen, can be the difference between hitting your target and missing it. EIZO developed its own integrated circuit to ensure your commands appear onscreen without delay.
Play like the pros with gaming presets from pro gamers such as Counter-Strike legend Patrik “cArn” Sättermon and Dota 2 player Johan “n0tail” Sundstein. Use the bundled software, ScreenManager Pro for Gaming, to download these and other presets from gaming.eizo.com or to export your own presets.
The FORIS FG2421 uses a new VA (vertical alignment) panel with a native contrast ratio of 5000:1. This is 5 times more than what other gaming monitors offer and increases the visibility in dark scenes so you can spot enemies more quickly.
The rear cabinet design features an LED backlit EIZO logo on a glossy surface surrounded by a vermillion frame. The logo glows brilliantly in a dimly-lit room or in a tournament setting. The front cabinet has a simple design so you can focus on the screen.
EIZO’s five-year warranty is two years or 67% longer than the standard three-year warranty of most brands.
Specification:-
- Panel Type: VA
- Size: 23.5" / 59.8cm (598mm diagonal)
- Native Resolution: 1920x1080 (16:9 aspect ratio)
- Display Size (HxV): 521.3 x 293.2mm
- Pixel Pitch: 0.272 x 0.272mm
- Grayscale Tones: 256 tones (a palette of 1021 tones)
- Display colours: 16.77 million from a palette of 1.06 billion
- Viewing Angles: 176 / 176
- Brightness: 400cd/m (Turbo 240: off)
- Contrast ratio: 5000:1 Typical (15000:1 with Contrast Enhancer)
- Response Time: Less than 1ms (Turbo 240: ON, Monito spec)
- Connections: 1x DisplayPort, 1x DVI-D (with HDCP) & 1x HDMI
- USB Hub: 2 Ports
- Power Saving: Less than 0.5W
- Standby Mode: Less than 0.5W
- Stand: 60mm Height adjust, 25 degress up tilt and 344 degrees swivel
- Dimensions: 563.5 x 391 - 451 x 200 mm
- Weight: 6.2kg
- Warranty: 5yr
- TFT Central Review: http://www.tftcentral.co.uk/reviews/eizo_fg2421.htm
ORDER NOW
Sorry for the shameless pimping, but I am sure I am not alone that £450 is way too much for a TN panel, WAY TOO MUCH. :(
Sounds nice, but the price. :eek:
That's more expensive than my 1440P IPS screen. :eek:
In that case apologies to you Matt, I like many others on here often jump the gun, thinking that some posts are written in a certain way to antagonize when in fact they are not meant that way.
So again apologies to you Matt.
No worries, thanks for the apology. :)
Just noticed this as well ;
I do need to make one side-note though the technology affects the display pipeline, it can reveal previously unnoticed glitches, stutters, and artifacts caused by the game engine or other PC operations. This can be caused by any number of different factors including texture loading, memory swaps, etc.
How can a tech that is supposed to reduce stutters, introduce them where they were previously unnoticed? :confused:
I guess everything comes with a caveat. I'm beginning to wonder what caveats Mantle will have.
