In a few days, that shall change and my god is the performance gain a nice one.![]()
Don't get my hopes up unless its deserved!!
EDIT
IN A FEW DAYS??
How can a tech that is supposed to reduce stutters, introduce them where they were previously unnoticed?![]()
Sorry, that is an absolute joke.
G-Sync’s value is best realized in specific scenarios where there’s a lot of frame rate variability - particularly between 30 and 60 fps. Staying in that sweet spot is tougher to do on a 1080p panel, especially if you’ve already invested in a pretty fast video card
Hmm so not so great if you run a sli rig, unless you are at a very high res, which means 4k or maybe 1440p and insane image quality. Ironic you can't use it with multi-monitor setups as it seems perfectly suited to that kind of res.
My guess would be that because frames are sent to the monitor as they are ready if there is a hiccup and a frame takes a little longer to render you would notice more readily than if you were using V-sync as the buffering would cover it up.Just noticed this as well ;
Problem for most I suspect, is actually finding somewhere that has them on display. Short of PCWorld or Curry's getting them (highly doubtful), there is nowhere near me for instance where I could go and see it.
We shall get some BenQ's on display, their prices seem to be over £100 cheaper, maybe even more, far better value. But looks like shall be nothing from them until Jan-March time, sorry can't be more specific.
I just hope a adaptor comes out so it works on any monitor so it doesnt have to have it built into it. I dont wana buy another monitor but i want the tech and i have a 670 and a nice dell st2410 monitor i dont wana discard. So with any luck there will be some sort of adatpro that plugs in the back of monitors somewhere that can override the inbuilt scaler or somit so i can enjoy gsync. And hopefully be far cheaper than a new monitor i.e 30 quid or so.
Hoping remember im hoping.
Will ocuk be testing this out on a killer setup?
